What's this thing and where does it go?
Old Dec 8, 2019 | 11:12 AM
dbelcourt's Avatar
dbelcourt is on a distinguished road
Default What's this thing and where does it go?
It's got a vacuum hose and a connector with two wires. What's it for?
Looks like it should be bolted somewhere. Currently I zipped tied it out of harms way. Where does it go?
This is a 1995 4wd Blazer. I don't think the 4wd locks in.
Old Dec 8, 2019 | 01:10 PM
Looks like a simple vacuum switch, like something that might turn on your 4x4 light when the front axle engages. Check the underhood vacuum hose diagram and see if you can find it there. Otherwise, maybe you can see what color the wires are and find it on a wiring diagram.
Old Dec 8, 2019 | 04:45 PM
odat's Avatar
Its part of the anti lock brake system - disables part of the anti lock system when in 4WD - I've seen them bolted to firewall and even wheel wells - find a spot that works and bolt it down .....
Old Dec 9, 2019 | 08:12 AM
dbelcourt's Avatar
Thanks!
skidud
Dec 12, 2011 01:32 PM
gcg
Dec 12, 2010 06:51 PM
christian1984
Nov 21, 2010 01:23 PM
GregNY
Jan 19, 2009 06:39 PM
noom14921992
Apr 22, 2008 08:44 PM
