1995 s10 blazer 4wd wiring plan searched
Old Nov 21, 2010 | 11:01 AM
christian1984's Avatar
christian1984 will become famous soon enough
Default 1995 s10 blazer 4wd wiring plan searched
Hi guys.
Since I bought my Blazer, my 4wd is broken.
So, thatīs the problem: the gear reduction locks in, but my 4wd not.
Yesterday, I spent all the day under the Blazer to identify the problem.
My result: the vacuum-hose to the Transfercase was cut (I think by the previous owner).
I repaired the hose, and the transfer-case locked up.
But then I noticed that the vacuum actuator for the axle-locking get no vacuum.
I tried to retrace the hose, but it going down between the firewall an the engine and I donīt know where it ends.
So I search something like a wiring plan from an all-data-program or something else.
If anyone could help me, it would be great.
The german GM-garages know only Opel an corean Chevrolets like Matiz and such f***ing pieces of s**t. They suggest, something like a Chevrolet Blazer wouldnīt exist in Germany although my Blazer stands on their parking lot. These fools.
So please, help me.
Thanks a lot.
Greetings from Germany
Old Nov 21, 2010 | 11:20 AM
robertr728's Avatar
robertr728 is on a distinguished road
This is all i could find hope it helps you out.
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
Old Nov 21, 2010 | 12:52 PM
Thank you!! Thatīs great!
Now I looked at the last pdf, and iīve seen on the vacuum switch are three pins.
One (A) comes from the engine an delivers the vacuum.
One goes directly to the Vacumm actuator (1).
The third goes to the transfer case (C) and the venting (B) with a tee?
Correct?
I think I found my mistake.
I think, I connect the delivery-hose direct to the transfer-case and so the transfer-case can lock in, but not the axles, because they get no vacuum?
Would that work?
Thanks for your help!!!
Old Nov 21, 2010 | 01:15 PM
robertr728's Avatar
Sounds possible if there is no vacuum getting to the front axle actuator it cannot engage the front axle.
Old Nov 21, 2010 | 01:23 PM
The problem is, in east-germany, no one has an idea about american cars.
My buddys are mechanics, but without a plan itīs not easy to find out the problem.
And the pre-owners were totally idiots. they bite through the parking brake wire and such bulls**t. But my buddy had a little idea with a venting hose, but we donīt knew which hose belonged on which pin.
In the next days I will try it out.
i will report my result.
So, thanks a lot, and have a nice evening.
tmoble
Jul 27, 2014 12:09 AM
Little Roober
Lifting Tech
Feb 13, 2012 10:02 PM
degaine_designs
The Chop Shop
15
Nov 29, 2009 02:48 AM
uberfiend
Apr 7, 2008 04:04 PM
skorned
Dec 25, 2006 11:49 PM
