Where to buy brake lines?
Old Aug 1, 2009 | 07:19 PM
jeffrozar's Avatar
jeffrozar is an unknown quantity at this point
Default Where to buy brake lines?
My 1998 ZR2 left front brake line rusted through at the hose connection and now I need to replace it. I got a new hose on from AutoZone, new banjo bolt, new bleeder screws.
My question is where do I get a new brake line? The brake lines go into the ABS unit, and that adapter is a different diameter (larger) than the adapter that screws into the hose by the wheel.
Also, any tips for removing the bolt that holds on the bracket to the upper a-arm? I cant get a wrench behind the a-arm, plus the bolt head is so rusted.
Thanks!
Old Aug 1, 2009 | 07:26 PM
bandidolenny's Avatar
I would try NAPA or Carquest. You can probably make the line yourself if you get a flair tool... it's really not that hard to do.
Just grind the bolt off and replace with a new one.
Old Aug 1, 2009 | 07:35 PM
jeffrozar's Avatar
Thanks. I was hoping to buy a pre-made ones I just have to bend.
Old Aug 1, 2009 | 07:37 PM
mikeinwi's Avatar
mikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud of
rockauto.com or gmpartsdirect.com should carry them too.
4.3vortec
Apr 1, 2014 09:17 PM
big_charms@hotmail.com
Mar 25, 2013 08:12 PM
mikekolb
Jul 26, 2009 11:59 PM
cherryred4x4
Mar 23, 2006 12:22 PM
