Where is the fuel pump
Old Jun 21, 2011 | 06:34 AM
  #21
MXer746's Avatar
MXer746 is on a distinguished road
Get a Haynes manual or a similar manual, lower the spare tire on the four door model, if yours has the spare under the rear. Make sure you used as much fuel as you could. Put a big piece of wood on a jack and put it under the tank. Make sure the wood doesn't cover the straps though. Disconnect the filler hose and fuel lines in the back and the vent lines in the front. disconnect the wire harness. Unbolt the rock guard on the left hand side by the rear wheel, and unbolt the straps and lower it. That's about it. The manuals will have pictures, and if you can't afford to buy one you can probably pick one up at the library. (Our Columbus library has several.) They really help.
BouncingRadical
14
Nov 27, 2015 12:30 AM
cide
Nov 7, 2009 01:26 PM
upblazer95
Mar 8, 2009 07:15 PM
Lckyctch
Dec 30, 2007 05:38 PM
mytruck2
Dec 13, 2006 04:50 PM
