Where's the BCM??? 2000 Blazer
Old Apr 20, 2010 | 07:23 AM
jimpasq57's Avatar
jimpasq57 is on a distinguished road
Default Where's the BCM??? 2000 Blazer
I have a 2000 Blazer, 4 WD. Can't locate the BCM. Anybody know where it is?
Thanks,
Jim
Old Apr 20, 2010 | 08:25 AM
RonJon's Avatar
RonJon is an unknown quantity at this point
Low center of the dash. Behind the center console if you have the holders or above it if you have the tray.
Old Apr 20, 2010 | 08:27 AM
Under the center of the dash mounted to the HVAC housing. It will have 3 electrical connectors running into it.
Old Apr 21, 2010 | 08:33 AM
jimpasq57's Avatar
Thanks guys!!
We'll be looking today!!!
Old Sep 5, 2011 | 05:01 PM
seekermeister's Avatar
seekermeister is on a distinguished road
That's handy, i was looking for the same answer, and this thread gave it. However, just to be clear, its behind the cover just above the center console...right? If so, I imagine that the center console would have to be removed first, and I was just looking, and saw no screws or other means of attachment. What holds it?
Old Nov 6, 2011 | 07:55 AM
msmith22's Avatar
msmith22 is on a distinguished road
Easiest way to access the BCM, is to remove the kickplate on the driver side, and its mounted by a plastic bracket about 10 inches up under the kick plate, almost directly behind the IP fuse box thats in the door jam. (but inside the dash)
The plastic bracket holding the BCM doesnt have any screws. it just unclips and clips back in.
hope this helps
PECAN
Oct 24, 2016 05:54 PM
Dodgeman
18
Nov 2, 2012 03:18 PM
GoofinOff
Jul 30, 2012 06:40 AM
vic98blazer
Feb 23, 2012 05:34 PM
seekermeister
Nov 16, 2011 01:34 PM
