will a 99 4.3 swap to a 02 or newer 4.3?
Old Nov 15, 2008 | 09:17 PM
brandahl's Avatar
brandahl is an unknown quantity at this point
Default will a 99 4.3 swap to a 02 or newer 4.3?
CanI replace my 99 Blazer 4.3 with a newer year engine. I am seeing lower mileage engines from 02 and up on Car-part.com, but it does not cross reference that engine. The newer ones have less miles, so I wondered if it was possible without to many changes.
Old Nov 16, 2008 | 10:25 AM
blazin97's Avatar
blazin97 is on a distinguished road
Default RE: will a 99 4.3 swap to a 02 or newer 4.3?
No you cant, for your 99 you need a 96-01 motor. in 02 they got rid of the EGR valve and changed the knock sensor with a dif. type.
Old Nov 16, 2008 | 01:29 PM
The knock sensor is the biggest hindrance. The removal of the EGR from the mid-02+ engines just means you would need to swap over the intake manifold, but you can use the SCFI spider from the newer engine with your intake.
It has not been confirmed or denied, but I would think that you could rewire the knock sensor to use the newer style mounting.
Old Nov 19, 2008 | 08:40 PM
Doverman454's Avatar
Doverman454 is an unknown quantity at this point
I had04 4.3 motor put into my 98 blazer all they have to do is tap the crank sensor bolt to a bigger size.
Umpquacod
Nov 9, 2009 11:14 AM
redfan13
Oct 1, 2008 02:35 PM
65longroof
Sep 22, 2008 10:39 PM
bigbill23
Tires and Wheels
Jul 5, 2007 11:03 PM
v8only
Jun 29, 2005 06:02 AM
