Will engine perorm right with out cat
Old Sep 11, 2008 | 11:26 PM
Bad Ramer Jamer's Avatar
Bad Ramer Jamer is an unknown quantity at this point
Default Will engine perorm right with out cat
Some nice guy stole my cat while I had my car parked where I store my car hauler. Cut it off with a sawzall. He got em off every car in the yard. [:@]Trashed my o2 sensor wire's too. But I just unplugged what was left. I put a piece of pipe in it for now. I can't afford a new cat at the moment. The car is running a little low on power it seem's like. I've had people tell me with the o2 sensor gone, it will run rich. The guy at a local shop said if the front sensor is gone it will effect performance. But mine is the rear sensor that is missing. He said it should be fine, other than throwing code's that don't neccesarily mean anything. What do you guy's think. Should I try to replace it asap, when I can afford it. Or will it be all right. Thank's.
Old Sep 12, 2008 | 07:08 AM
Default RE: Will engine perorm right with out cat
Do to federal regulations, you are required to have a functioning catalytic converter on any vehicle equipped with one from the factory. I would file a police report to get some documentation and then replace it when you can.
The aftermarket catalytic converters, while they do not last as long as OEM ones, can be purchased for around $60 for a universal.
As far as the O2 sensor is concerned, it is fine to run without the rear sensor so long as you do not mind the check engine or service engine soon light being on.
hillbillys10
Apr 14, 2013 01:04 PM
Squad-6
Headers, Intake, & Exhaust
May 17, 2011 10:29 PM
Bullfrog2099
Dec 16, 2010 07:25 PM
PaulO2288
17
Jan 20, 2010 01:39 PM
djbass_mekanik
Apr 22, 2006 06:15 AM
