will not start
Old Dec 31, 2006 | 06:36 PM
tommy's Avatar
tommy is an unknown quantity at this point
Default will not start
HI ALL
IT IS A 1998 BLAZER 4X4 WITH A 4.3 LITER. CHANGE THE INTAKE MANIFOLD GASKETS. GETTING FUEL AND SPARK,BUT IT STILL WON'T START. THE ENGINE CHECK LITE IS ON, WHEN THE KEY IS IN THE ON POSTION. ANY SUGGESTION?
THANKS TOMMY
Old Dec 31, 2006 | 06:51 PM
20Blazer00's Avatar
Default RE: will not start
when you removed the distributor did you mark the rotor location before lifting out and at the end of lifting out...soundsl like it could be a timing issue. Did you rotate the engine in any way after removing the distributor???
hope this helps and by the way don't use all caps it is disrespectful to SHOUT!!!!!!
Old Dec 31, 2006 | 07:23 PM
tommy's Avatar
first of sorry for caps, secondly yes i install distributor the same way i removed it.
Old Dec 31, 2006 | 07:27 PM
MNHawk's Avatar
MNHawk is an unknown quantity at this point
Its easy to get it off by a tooth or two.
Might help to line the crank up to TDC 0 and then check the rotor to cap relation.
stschuyler25
Nov 21, 2010 09:34 AM
wayland
Dec 9, 2009 12:38 PM
blazerJim1701
Jul 26, 2009 09:18 PM
actionpaintball
Jul 14, 2006 07:53 PM
