will start but wont stay that way please help
Old Jun 30, 2008 | 09:37 PM
00blazerLS's Avatar
00blazerLS is an unknown quantity at this point
Default RE: will start but wont stay that way please help
does anyone know if a faulty crankshaft position sensor and or camshaft position sensor can cause vehicle to stall while driving??? found website of chevy malibu's doing same thing my blazer is and it was due to the crankshaft sensor. does anyone know?????
Old Jul 1, 2008 | 06:30 AM
It is very possible, but they typically trigger a code.
Old Jul 1, 2008 | 01:36 PM
rriddle3's Avatar
ORIGINAL: 00blazerLS
...acts like there is nothing wrong with it besides small little back fires from reving it up...
...something diffrent i have noticed ever since it died the first time is a little backfire when it is reved up. not sure why its doing that but it still idles fine...
Hhmmm, wonder if the ignition coil might be dying?
Old Jul 1, 2008 | 04:20 PM
skoot61's Avatar
skoot61 is an unknown quantity at this point
Can the crankshaft position sensor the camshaft position sensor and the ignition switch be bench tested like you can do with the Ignition Control Module?
Old Jul 1, 2008 | 04:45 PM
00blazerLS's Avatar
i believe my repair book mentions a way that you can test it. what it does not mention though is the relearn procedure other people have talked about having to do once replacing the crankshaft sensor. i would think if it was a must it would mention that in the replacing procedure.
Old Jul 1, 2008 | 05:26 PM
2drblazer's Avatar
2drblazer is an unknown quantity at this point
yea test ur pressure go to advaned and get a high pressure tester i had that problem mine was at 50 and was not enough i needed 60 to 66 hope this helps its worth the 40 $ for a pressure tester
Old Jul 6, 2008 | 04:32 PM
00blazerLS's Avatar
ok well after many hours of trying to find people with similar problems and trying to diagnose what was wrong with vehicle without buying one part after another it turned out to be a failing coil pack. so supposedly when it gets hot it can stop working and not create enough or no spark at all causing a stall. once it cools down it works again. so far blazer drives fine. have not driven too far with it yet but no problems and no codes after it finished going through its necessary cycles. so for now its fixed but if it stalls again i will let everyone know. thanks for everyones input :-)
Old Jul 6, 2008 | 07:44 PM
rriddle3's Avatar
ORIGINAL: rriddle3
ok well after many hours of trying to find people with similar problems and trying to diagnose what was wrong with vehicle without buying one part after another it turned out to be a failing coil pack. so supposedly when it gets hot it can stop working and not create enough or no spark at all causing a stall. once it cools down it works again...
Dang, glad that was what it was, becauseit was the last idea I had to offer. Hope that cures the problem. Think I'll get myself a beer. [sm=icon_cheers.gif].
zblazerz
Apr 8, 2015 12:22 AM
syriusly
Feb 23, 2013 07:04 AM
DaddysBlazer
Sep 6, 2011 04:50 PM
bommaritomike
Nov 19, 2010 06:56 PM
K5BeAst87
Nov 5, 2010 11:51 AM
