Winter weight?
Old Dec 2, 2006 | 06:41 PM
Pugsley's Avatar
Pugsley is an unknown quantity at this point
Default Winter weight?
This will be my second winter driving my '03 2WD Blazer, and I haven't quite yet found out the ideal amount of weight to put in the back. I'm concerned about having enough weight to get traction from a stop (especially on inclines). Last year, I used two 70lb. sandbags; is this enough with such a light rear end?
Anyone have any tips or recommendations?
Old Dec 2, 2006 | 10:50 PM
Chevy Lover's Avatar
Default RE: Winter weight?
So how did it handle last year?
I have older, heavier 4x4's, but if I had a lghter, newer 2WD I'd probably put about 200lbs of sand and a 50 lb bag of salt in the back. I guess it depends on what kind/condition of tires you have on and if it's a standard or automatic. I hate automatics in the snow, you almost have to throw them in neutral to stop sometimes.
Old Dec 3, 2006 | 12:57 AM
blazinloud's Avatar
why does putting it in neutral help?
Old Dec 3, 2006 | 01:56 AM
It helps when you're stopping on a slippery surface, if you put it in neutral the tranny isn't trying to push you.
With a standard you can down shift or step on the clutch.
Old Dec 3, 2006 | 02:08 AM
a_tack's Avatar
a_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud of
i drove 3 long winters in a 2wd ford ranger... approximately the same weight as a blazer..... a good set of snow tires and 200lbs. of sand got me anywhere I needed to go..... but yeah... neutral when stopping, and even with an auto if you are going down a snow covered hill, drop your tranny down into 1...... lightly tap your brakes the whole way down... you will be good to go. a couple of drives in the snow and you'll be a pro...
Old Dec 3, 2006 | 09:03 PM
Mbastet99's Avatar
Mbastet99 is an unknown quantity at this point
My dad taught me about shifting to Neutral, and downshifting to 1 back when he first took me out for driving lessons. It's worked great in any vehicle I've ever owned on slick snow and ice.
Sisk
Dec 28, 2009 09:19 AM
Dhurteau
Nov 5, 2007 01:20 AM
GMdesigner
Sep 22, 2007 12:16 AM
DetroitMuscle
Sep 30, 2006 10:40 AM
ivannj
Jan 31, 2006 01:45 AM
