Wiring Scem fuel assembly?
Old Feb 5, 2013 | 08:37 PM
Scarakus's Avatar
Scarakus is on a distinguished road
fuel pump prime relay, it comes on for two seconds then off till you crank the motor
i just measured voltage while cranking, it went down to 9.6v.
so it seems the wiring should be ok? it has to be the pump.
Old Feb 5, 2013 | 08:48 PM
Not necessarily. It's always best to diagnose it properly... unless money is not an issue. In that case, just go buy another vehicle Test fuel pressure and leakdown first, the results will tell where to look next.
Old Feb 5, 2013 | 09:00 PM
Scarakus's Avatar
yeA I expected to get an eye & face full of gas.
Old Feb 5, 2013 | 09:08 PM
There might be a problem with the schrader valve not allowing fuel past while checking pressure. That could explain the low reading. Get a different pressure tester and try it again. If it gives you the same result, (10psi) remove the schrader, connect the tester and try it again.
jjnemoiii
Nov 6, 2009 10:59 PM
gw2009
Jan 12, 2009 05:04 PM
guywm25
Apr 11, 2008 08:28 AM
junkmonkey
Mar 29, 2007 08:01 PM
LunchBox
Jun 19, 2006 08:35 AM
