Won't idle with breather off
Old Oct 26, 2011 | 12:46 PM
EdC's Avatar
EdC
EdC is on a distinguished road
Default Won't idle with breather off
Thought I had posted this last week, but it never showed up. So here goes again.
About every year or so my throttle has a tendency to stick if I press the gas pedal. A quick shot of Carb cleaner in the TBI with the engine running usually clears it up. So last week I loosened the breather (2000 4.3 v6) started the engine and took the breather off the TBI. The engine stalled within about 3 seconds after removal of the breather. Throttle was in closed position and there was a sound like a vacuum. It was more intense than you wound normally hear on a normal leak. There was no Vacuum noise before the breather was removed. I was able to squirt a little cleaner to get the throttle free, the the fact that it won't idle is bothering me. Any thoughts on this or has anyone come across this before?
Old Oct 26, 2011 | 12:50 PM
Normal operation. When you disconnect the intake system from the throttle body, little to no air is being drawn through the MAF. MAF readings are critical to engine operation. Next time, disconnect the MAF sensor and then start the engine. It'll run that way!
Old Oct 26, 2011 | 04:29 PM
rriddle3's Avatar
Originally Posted by EdC
Thought I had posted this last week, but it never showed up. So here goes again...
Actually, you posted it on 10-17, but nobody replied to it. I have now closed that thread.
DKSDAD
Aug 4, 2009 09:30 PM
portcqb
May 8, 2008 10:45 PM
Sorell
Feb 24, 2008 08:58 PM
riceh8r0512
Sep 10, 2007 08:50 PM
johnliester
Jun 13, 2006 12:33 AM
