yet again another 4wd problem
Old Feb 21, 2010 | 05:04 PM
Spectreblazer's Avatar
Banned
Spectreblazer is on a distinguished road
allright heres the story. i went to cut wood and we drove the blazer back through the corn field. nothing crazy just nice and easy. when i left i put in 4wd. worked fine. done cutting wood and ready to head back to the house is when problems started. i went to pull out and the back tire was spinning. (i had it in 2wd). no worrys put it in 4hi. front axle engages and im able to get out. keep driving along and i notice the 4hi idicator light is still flashing. so i put it back in 2hi and the lights turns solid on the 2hi indicator and all is well. so my 4wd is working but the indicator light will not stop blinking. i got up underneath afterwards to see if a vac line disengage and i have not found any,(not saying rule out the possibility, but i didn't see any) i have a 2000 blazer LS. has has this been discussed before? i searched a little but didn't find exact symptoms.
thanks again for all help
-dave
new video of whats happening will be up shortly (its uploading and should be up after i get done with work after 5:30)
also the encoder motor was changed about 3 years ago. im leaning more towards the vac actuator failing. i read kyle's post on 4x4 common problems and it said it takes an extended time for the idicator light to come on. anyone know how to test the actuator or can point me in the right direction.
Last edited by Spectreblazer; Feb 22, 2010 at 01:24 PM. Reason: *Combining Consecutive Posts* - Please use the EDIT feature to include additional information in your post if another member has not replied.
Old Feb 22, 2010 | 05:45 PM
Banned
:bump:
http://www.youtube.com/watch?v=xOgZvf7KqGQ
really poor video quality sorry.
Old Feb 23, 2010 | 06:49 PM
Banned
thanks guys lol. anyways i figured it out today once i got it on the lift. all the vac lines checked out A ok . looking at the front diff there is a sensor just about in the middle. it was slightly seperated from the harness. i re-snapped the connector on. took her for a test drive and she works great. must have been a corn stalk yanked it out
El Heffe
Feb 6, 2015 12:33 PM
brooklynRick
Jan 30, 2011 03:49 PM
macisme
Feb 26, 2010 04:55 AM
vetteandblazerman
Oct 29, 2009 03:57 PM
blazin_j
Oct 17, 2009 06:38 PM
