98-05 S-Series Radio Removal HOW-TO Discussion
Old Jul 11, 2007 | 10:58 AM
  #21
ChrisAttebery's Avatar
ChrisAttebery is an unknown quantity at this point
Default RE: Jimmy/Blazer Radio removel How To!!!PICS
Actually, the piece I had to cut was the rear radio support. It was about 1/2" too tall and was hitting the back of the Sony. Once I cut it down the Sony sat flush with the dash.
Old Jul 11, 2007 | 11:14 AM
  #22
drperry's Avatar
ahhhh
I know what your talking about... My Alpine doesn't touch it, so I'm not worried, lol
Old Jul 18, 2007 | 06:06 PM
  #23
getonerd's Avatar
getonerd is an unknown quantity at this point
http://www.installdr.com/InstallDocs/GM/PDF/460001.pdf
Old Jul 18, 2007 | 08:05 PM
  #24
mrlazlo's Avatar
mrlazlo is an unknown quantity at this point
So does the Blue 4x4 just unplug as well as the rear window buttons below it? or do u have to unhook like some little snap things?
Old Jul 18, 2007 | 08:24 PM
  #25
hillbillyinOhio's Avatar
the 4x4 can pop out of the dash, and it is a plug. the hatch release is just a plug, that you have to release from the drivers side of the plug.
Old Sep 20, 2007 | 09:00 AM
  #26
chevys rule's Avatar
chevys rule is an unknown quantity at this point
ORIGINAL: hillbillyinOhio
oh, and btw, you dont need an interface. if you had another harness that went into that black plug, then yes you do. The standard 70-2003 harness will work just fine, and retain the RAP.
Thanks for letting me know,I still haven't gotten around to my own truck yet the screen is just sitting here,And I got the Jimmy in June LOL
But what was this all about if you had the RDS stock HU you have to get a interface to keep the RAP,I still going to use that 70-2003 harness and see if it works.
Old Sep 21, 2007 | 09:31 AM
  #27
Where did you guys do your ground wire??? or did you just use the Ground wire in the Metra harness with the one from the Aftermarket one.
Old Sep 21, 2007 | 11:19 AM
  #28
just ground to the black in the metra harness.
Old Sep 21, 2007 | 03:12 PM
  #29
Thats what I always do most of the time anyways but just checking as I never have worked on a jimmy
To my quesion in the PM Sent you Rudy,I was just looking at the fuse panel again and saw this
19-radio/batt 15A clarion 15amp
24-radio/ign 10a
Also I know I probly have already talked this to death on the MSN last night with you,But when I use the Fuse tap or acc power I will LOSE the RAP right.I was talking another isntaller today and he said it will still be there IE power windows work but No radio will stay on unless the key is in the Acc/run postion.
This is correct right
Old Sep 21, 2007 | 04:08 PM
  #30
if you tap the accessory, i believe that it will stay hot until you open your door. grab your fluke and test it!
