Fuel Filter Replacement How-To-Write Up - DISCUSSION THREAD
Old Feb 12, 2010 | 04:44 PM
  #31
That applies to incandescent bulbs. Florescent and LED lights won't have this issue.
Old Feb 12, 2010 | 08:10 PM
  #32
Spectreblazer's Avatar
Banned
Spectreblazer is on a distinguished road
great write up lenny,
i used this the last time i changed mine.
Old Feb 24, 2010 | 11:00 AM
  #33
chrisf719's Avatar
chrisf719 is on a distinguished road
Thanks Lenny I'm sure this will come in handy when I do mine in a couple weeks!!
Old Mar 5, 2010 | 06:46 PM
  #34
camaroz's Avatar
camaroz is an unknown quantity at this point
I found that putting on the new filter was a snug fit, and it was super snug, was to let the bracket sit in some HOT water for a couple of minutes. The new filter slipped on a lot easier.
Old Mar 16, 2010 | 03:56 PM
  #35
TripleBlackBlazer's Avatar
Just changed mine at 99k miles. Filter wasn't hard to remove. I had already done this on the Wife's Regal when we first got it so I was prepared for gas still being in the line even after removing the fuse and cranking it a couple of times. Everything went smoothly and there were definitely lots of particles in the old filter when I dropped the line into a catch can.
Thanks for the write-up. I used a little silicone spray on the bracket before sliding the filter back into it.
My last trip was 18.5 mpg, 100% highway (as compared to 21 mpg, 100% highway when I first got it) so we'll see how much the new filter helps. Of course, I also need new plugs and wires and wouldn't hurt to replace cap and rotor as well...
Old Mar 17, 2010 | 04:11 PM
  #36
flipzat's Avatar
flipzat is on a distinguished road
is a 16mm wrench the only thing that will fit on mine slips
Old Mar 17, 2010 | 07:13 PM
  #37
terry s's Avatar
terry s is on a distinguished road
I do not think they are metric. If they are tight you should use a flare nut wrench on the nuts and a good fitting open end wrench on the filter nut. Place the wrenches so you can squeeze them together to loosen the nut. It usually works better and can save some skinned knuckles. A flare nut wrench is a 6-point box end wrench that has a notch missing so it will just barely fit over the fuel line. It gives the most grip to avoid rounding off the nut. If you do round off the nut you have to resort to vice grips.
Old Sep 7, 2010 | 05:32 PM
  #38
dougn85's Avatar
dougn85 is on a distinguished road
Default whet a little different but worked
The fitting was stuck but i got the filter cranked on by rotating the filter on to it till tight, looks good , no leaks. I geuss that worked
Cuz the front end of filter rotates freely while clipped.
Old Nov 27, 2010 | 02:48 PM
  #39
Vicer_Exciser's Avatar
Vicer_Exciser is on a distinguished road
easiest my ***, this has been a pain
Old Nov 27, 2010 | 03:38 PM
  #40
Brianator99's Avatar
Brianator99 is an unknown quantity at this point
It's so easy a caveman can do it.
