How to: Quad Beam Mod 2nd Gen - DISCUSSION THREAD
boost3d, I used one relay relay... I don't remember exactly but I did some research and here is what I came up with - the numbers relate to the ones on the relay so the wires should go from that number prong on the relay to the wire specified. Hope it works. when I have time, I will take my headlight assembly apart and take some pics.
30 - Vehicle Ground
85 - High Beam wire - Purple Wire
86 - Low Beam wire - I think its the yellow one
87 - Low Beam Ground wire - I think it is the blue one
30 - Vehicle Ground
30 - Vehicle Ground
30 - Vehicle Ground
I wish I had a wiring diagram for the 2000, I could make sense as to what's going on by jumping Yellow to ground, if all else failed, I'd create my own setup.
What makes me a bit nervous is that one guy said he burnt a wire on his steering column.
http://www.zr2usa.com/mboard/index.p...pic=6098&st=40
I did the first mentioned method (grounding the yellow wire on the low beam) on my 02', and it works AWESOME!!! My only problem, which I noticed today, is that as soon as I shift it into gear, my low beams come on full blast, and I cannot kill them! They are not on while in park. I did do the DRL (bending the fuses) / AHL (relay) disable. Is there something I can do to stop my lights from comming on automatically?
And, I did try just grounding the drivers side, and just the passengers side separatly, but to no avail. There must be something...when in gear, they still shut off when I engage the e-brake...I totally give up!
