How to: Quad Beam Mod 2nd Gen - DISCUSSION THREAD
Old Mar 3, 2012 | 03:51 PM
  #61
alpinesubs's Avatar
alpinesubs is on a distinguished road
Originally Posted by Tony H
Only needed to do one side. no harm done.
That was my understanding of the original thread also. It might just be my truck but I had to ground out the yellow wire on both sides to get quad beam on both headlamps.
Old Mar 3, 2012 | 05:20 PM
  #62
97cherryblazer's Avatar
97cherryblazer has a spectacular aura about97cherryblazer has a spectacular aura about
Ok so for my 97 i have to follow the second set of instructions or can i follow the first set? im confused. I read the comments and it looks like the first set is only for the 98+?
Old Nov 18, 2012 | 11:49 AM
  #63
svd85's Avatar
svd85 is an unknown quantity at this point
A member messaged me and asked how I wired my 2000 Chevy Blazer with my HID kit. I made a video to show him. Here it is: https://www.youtube.com/watch?v=27IEk10InnM
This is how I wired it using a 12VDC 30/40A relay.
30 -- Blue - Low Beam Positive
85 -- White - High Beam Negative
86 -- Black - High Beam Positive
87 -- Yellow - Ground
In theory, it should work the same without the HID kit and you would just tap into the stock wires. Hope this helps.
Old Dec 11, 2012 | 05:19 PM
  #64
xgiovannix12's Avatar
Just curious will this work on an 92 k1500 ?
Edit: I might need to go with a relay system.
Old Feb 11, 2013 | 06:14 PM
  #65
BigT270's Avatar
BigT270 is on a distinguished road
Found this mod a little to late. I just bought the LMC relay kit. Went to put it on, and couldn't help but notice the wire colors on my 95 Jimmy were different. It says to splice the yellow and purple, and brown wire separately for the park lamps.
After reading through here, let me see if I have it right. I splice the Tan wire to the yellow, and the light green to the purple on the harness kit?
Old May 12, 2013 | 01:12 PM
  #66
Thager's Avatar
Thager is on a distinguished road
just did the yellow wire mod today,i only grounded the drivers side, here are some pics.
tapped in to the yellow wire
wire pulled through rad support and and attached to exsting ground
to make reinstalling the headlight easyer i cut the nubs off the back (see green circles)
low beam
hi beam
Attached Thumbnails How to: Quad Beam Mod 2nd Gen - DISCUSSION THREAD-img_1038.jpg   How to: Quad Beam Mod 2nd Gen - DISCUSSION THREAD-img_1040.jpg   How to: Quad Beam Mod 2nd Gen - DISCUSSION THREAD-95ee82a9-161e-4090-9108-b75f106ff22b.jpg   How to: Quad Beam Mod 2nd Gen - DISCUSSION THREAD-img_1042.jpg   How to: Quad Beam Mod 2nd Gen - DISCUSSION THREAD-img_1043.jpg
Old Jun 20, 2013 | 02:10 AM
  #67
tommyraybradley's Avatar
tommyraybradley is on a distinguished road
I just did mine. Grounded yellow wire on drivers side only, no issues.
Attached Thumbnails How to: Quad Beam Mod 2nd Gen - DISCUSSION THREAD-tommyraybradley-54551-albums-lights-7146-picture-quad-beam-mod-26752.jpg
Old Sep 17, 2013 | 09:56 PM
  #68
Thager's Avatar
update, it stopped working so i grounded both sides now and it works again
Old Sep 19, 2013 | 09:20 AM
  #69
HostileJava's Avatar
HostileJava is on a distinguished road
Stopped working period or stopped working on one side, it may have just been a poor ground.
Old Sep 19, 2013 | 10:56 AM
  #70
Dobe Rottie Gang's Avatar
Dobe Rottie Gang is on a distinguished road
This is such an interesting thread to read as the UK model Blazer comes with the quad beam mod already installed.
I have checked both of my Blazers and I can have either the dip lights on, mean beam on or all four just by controlling the stalk on the steering column.
That's another differences I have found between the UK and US models.
