How to: Quad Beam Mod 2nd Gen - DISCUSSION THREAD
Old Jun 2, 2011 | 10:35 AM
  #41
TMM217's Avatar
TMM217 is on a distinguished road
Alright so i grounded out the low beam yellow wire and the quad beam seems to stay on with the daytime runnin lights. Thats how it is right? cause seems that whenever highbeams are on either high or DRL the quad beams will be on. Is this the way its suppose to work?
Old Jun 2, 2011 | 09:29 PM
  #42
TMM217's Avatar
n e one do this modv and have the same results i did?
Old Jun 5, 2011 | 08:58 PM
  #43
zedartwo's Avatar
Please don't use short forms. Its hard for some to read!
AS for your question, I don't think you did it correct. It is supposed to be that when you turn the highbeams on, the low beam stay on as well. It should not affect the DRLs. Do you have a ZR2?
Old Jun 20, 2011 | 01:47 PM
  #44
9Blazer6's Avatar
9Blazer6 is on a distinguished road
Well since nobody has really been talking about the 95-97 blazer non zr2. Im going to ask. The DIY that was posted on page one...is that for the 95-97? Just ground the yellow wire out on one side or each side? Low beams stay on when pull lever back for high beams? i'll give it a whirl later and post pics.
Old Jul 6, 2011 | 08:52 PM
  #45
zedartwo's Avatar
I'm not overly sure about that. But it is the yellow on both sides.
Old Jul 7, 2011 | 07:14 AM
  #46
Tony H's Avatar
Tony H is an unknown quantity at this point
Yes... When I did my daughters '99 all four beams come on in DRL mode. That;s OK with me.. It's daylight out anyway so no oncoming traffic seems to mind.
Old Jul 9, 2011 | 12:02 AM
  #47
Ugly_Monkey's Avatar
Ugly_Monkey is an unknown quantity at this point
This is the design i used:
I only enable "Quad mode" when I want to use it.
Original Thread
Old Nov 18, 2011 | 02:31 AM
  #48
gojorg's Avatar
I'm a little confused, so for my 2000 blazer lt the options for quad beam is rigging a relay or swapping wires at the steering column?
Old Nov 18, 2011 | 07:18 AM
  #49
Tony H's Avatar
No, its a matter of taking out one of the Bulb fixtures ( drivers or passenger) and grounding teh yellow wire in the Bulb harness.
Old Nov 18, 2011 | 10:43 AM
  #50
Benedict1337's Avatar
I grounded mine to the radiator support
