Lift Shackle Installation - DISCUSSION THREAD
Old May 31, 2011 | 03:58 PM
  #21
BigEffingHammer's Avatar
BigEffingHammer is on a distinguished road
A'ight, thanks
Old Jun 15, 2011 | 10:10 PM
  #22
98chevyblazer's Avatar
98chevyblazer is on a distinguished road
Quick question. When you try to fit 31's after the shackle and t bar crank, do you need to cut the fenders at all because of rubbing?
Old Jun 15, 2011 | 10:25 PM
  #23
Rottidog's Avatar
Depends on the offset of the rims & how much was the T-Bar crank & what length shackles. A "2" shackle (over stock) only gives you 1" of lift because it's only lifting 1/2 of the rear leaf spring
So a pair of shackles 2" longer than stock only equal 1" of rear lift.
Old Jun 15, 2011 | 10:40 PM
  #24
So what mdehoogh did actually only gave him 1" rear lift?
Old Jun 16, 2011 | 07:56 AM
  #25
mdehoogh's Avatar
I didn't measure the shackles before hand but they gave me almost exactly 2" of lift (meaning they were 4" longer than stock). You really don't need to bother with the exact measurements though unless you plan on making them yourself. If you see something listed as a "2 inch lift shackle", generally they mean it will give 2" of lift.
To answer your other question though, I did have to trim my front fenders.
Old Jun 16, 2011 | 12:10 PM
  #26
xgiovannix12's Avatar
so 2 inch shackles only give 1 inch lift?
Old Jun 16, 2011 | 12:15 PM
  #27
TheRandom1's Avatar
If it's advertised as a 2" lift shackle, you'll get 2" of lift. If the shackle itself is only 2" longer than stock, you get 1" is the way I'm understanding it. Basically. the 2 inch lift shackles are 4 inches longer than stock.
Old Jun 16, 2011 | 12:16 PM
  #28
Rottidog's Avatar
Yup, you have to make sure about the distance longer than stock. 2" longer = 1" lift because it's only moving half the leaf spring.
Old Jun 16, 2011 | 12:17 PM
  #29
yea i thought so that last reply got me confused lol
Old Jun 16, 2011 | 12:19 PM
  #30
im going to be buying these 2
they look 2 inches longer then stock ( i hope )
