Lift Shackle Installation - DISCUSSION THREAD
Old Jun 16, 2011 | 12:25 PM
  #31
TheRandom1's Avatar
I'd email them first to make sure. It sounds like they're going to give you a 1" lift not 2.
Old Jun 16, 2011 | 02:38 PM
  #32
xgiovannix12's Avatar
yea thats what i did lol
Old Jun 16, 2011 | 02:43 PM
  #33
TheRandom1's Avatar
A smart man, you are! lol
Old Jun 16, 2011 | 02:45 PM
  #34
thats what my blazer looks like right now on my sig hopefully a 2 inch shackle and a 1.5 tbar crank would make it look higher then it is now
Old Jun 16, 2011 | 03:09 PM
  #35
Old Skool Soldier's Avatar
Old Skool Soldier is on a distinguished road
I just got my 2" shackles from ebay in the mail. From bolt hole to bolt hole, they measure 7". I'll take some pics when I get them on, hopefully it goes smooth. I greased the bolts this morning
-OSS
Old Jun 16, 2011 | 03:17 PM
  #36
mdehoogh's Avatar
Awesome! Hopefully the bolts won't be difficult to remove.
Old Jun 16, 2011 | 04:13 PM
  #37
Rottidog's Avatar
im going to be buying these 2
they look 2 inches longer then stock ( i hope )
I'd measure yours from center to center of the bolt holes & ask them to do the same. Then compare. That way you'll know for sure how much lift you'll get. If the new ones measure C/C of the bolt holes 2" longer you'll have 1" of lift.
Old Jun 16, 2011 | 09:31 PM
  #38
Yep, complete failure today boys! Got the truck up high enough so the rear end was hanging, got the nuts off on the pass side using my rachet & breaker bar, but those damn bolts wouldn't budge. I measured 2.5cm of threads exposed (where the nut was). I cranked n cranked to no avil. I sprayed soap n water on the bushings, still nothing. After an hour, still 2.5cm of exposed thread. I'm gonna run a search on how to get the bolts out, was goin nuts! Might break down and pay a shop to do it
-OSS
Old Jun 16, 2011 | 09:40 PM
  #39
Ouch hopefully i could do it with no problem =X
Old Jun 16, 2011 | 10:11 PM
  #40
mdehoogh's Avatar
Try an air-hammer
If there's a harbor freight near you, they have an ultracheap version for about $12 that should get the bolts out. Otherwise you could try a sledge hammer on them if there's enough room to swing.
