Lift Shackle Installation - DISCUSSION THREAD
Old Jun 22, 2011 | 07:59 PM
  #51
xgiovannix12's Avatar
Hey guys today i bought shackles . now 2 inch lift shackles are 8 inches between holes if im correct. The ones i bought are 8 1/2 inches . that means imma get 2 1/2 inch lift?
would it look good with an 1.5 inch tbar crank?
Old Jun 22, 2011 | 09:36 PM
  #52
davedidit's Avatar
davedidit is on a distinguished road
2 inch lift shackles and a add a leaf spring
cranked the t bar keys all the way then back off 1/4 turn
2.75" from stock
stuffed 31 x 10.50 x 15 BF Goodrich Mud TA's KM2's
not the smoothest ride
had to do some triming
no frame rubbing
oh yea I put a 2 degree wedge for the drive shaft angle
the bad thing with the full t bar crank is the cv shafts in front
it eats up the boots but it's a ez change just over 2 hours for both sides
the guys at Checker auto parts don't like me lifetime warranty you bet
as for the ball joints keep them greased !!!!!
to top it off the rear shackle bushings I used a grinder to cut off the nut
then used a drill to drill out the bushing was ez
good luck
Old Jun 22, 2011 | 09:50 PM
  #53
2.75" from stock
no frame rubbing
good luck
no no what happen was i know 2 inch shackles have the holes 8 inches apart from each other.
i bought these shackles today and the holes are 8 1/2 inches apart now then means im going to get 2 inches 1/2 lift if im correct .
im also doing a 1.5 tbar crank in the front . would it look even ? or a little high in the back
heres a pic of the shackles
Attached Thumbnails Lift Shackle Installation - DISCUSSION THREAD-dfgdghdfgfdgd.jpg
Old Jun 22, 2011 | 09:58 PM
  #54
Rottidog's Avatar
I'm not sure what I read BUT - stock measurements (center of bolt hole to center of bolt hole, or bottom of bolt hole to bottom of bolt hole & + 2" = 1" of lift. Thats because you're lifting only half the rear leaf. (one side/end of it)
So lets say you have a shackle that's 2" longer than stock, that equals 1" of lift if only applied to 1 shackle. That's it - 1 inch of lift in the rear.
If your stock shackles are 8" & you got 8-1/2" shackles (measured from the same places) you have 1/4" lift in the rear!
Old Jun 22, 2011 | 10:07 PM
  #55
my stocks are 4 inches and the new ones are 8 1/2
Old Jun 22, 2011 | 10:16 PM
  #56
Rottidog's Avatar
Then you'd have 4 1/4" lift - if the bolt center to center are the same
Old Jun 22, 2011 | 10:17 PM
  #57
Rottidog's Avatar
I'm off to give my pillow some head lol... hagn
Old Jun 22, 2011 | 10:18 PM
  #58
someone told me that every 1 inch added to the shackle is 1/2 lift . i think it sounds about right
Old Jun 23, 2011 | 07:14 AM
  #59
You take the new length minus the stock length, then divide by 2.
( 8.5 - 4 ) / 2 = 4.5 / 2 = 2.25
Old Jun 23, 2011 | 10:36 AM
  #60
yea just wanted to make sure i was doing it right thanks swartlkk
