so you want a tire carrier on your 4 door?? - DISCUSSION THREAD
Old Apr 24, 2013 | 10:10 AM
  #451
El_Beautor's Avatar
Wow... That thing looks massive. From behind all you can see is tire!
Old May 19, 2013 | 08:08 AM
  #452
CPLSeraphim's Avatar
CPLSeraphim is on a distinguished road
That looks good. On my old wrangler I had a 38" spare. Backing up your wait for the crunch. lol. Definitely looking forward to this mod, if only I can find a tire carrier around here...
Old May 20, 2013 | 11:42 PM
  #453
joshn444's Avatar
joshn444 is on a distinguished road
Does any body know what tools you need to remove the tire rack from the donor. I'm going to pull a part junk yard this weekend and have to bring my own tools.
Old May 21, 2013 | 08:01 AM
  #454
greencactus3's Avatar
greencactus3 is on a distinguished road
i think torx bits are all you need.
Old May 22, 2013 | 12:00 PM
  #455
Diaita's Avatar
I'm pretty sure it's a T50 torx to pull the carrier hinges. The latch plate is torx as well, I think it was a T25, but I can remember for sure. If there is a tire on the carrier it probably has the wheel lock on it still, but if you don't have a key, a hammer and smaller chisel makes quick work of the wheel lock.
Old May 22, 2013 | 12:58 PM
  #456
Diaita's Avatar
I forgot to post the pics of the support brackets from the 2 door. These are in behind the sheet metal:
I cut them to look like this:
Old May 22, 2013 | 02:04 PM
  #457
El_Beautor's Avatar
Cool. What did you have to do to get those braces behind the sheet metal?
Old May 22, 2013 | 02:24 PM
  #458
Diaita's Avatar
Lets just say than no one will be buying that rear corner off the Blazer that I liberated it from...
Old May 22, 2013 | 02:59 PM
  #459
El_Beautor's Avatar
Sweet. How much did you have to chop on your own to get them in position?
Old May 22, 2013 | 05:25 PM
  #460
Diaita's Avatar
The holes are about 3"+ square. The holes could have been smaller, but I couldn't find a smaller hole saw in my set that still had teeth. I used SikaFlex to adhere and seal them to the inside of the sheet metal
Attached Thumbnails so you want a tire carrier on your 4 door?? - DISCUSSION THREAD-20130409_185104.jpg
