1993 s-blazer double din
Old Dec 30, 2009 | 08:38 PM
jshultz78's Avatar
jshultz78 is on a distinguished road
Cool 1993 s-blazer double din finished install
I've finally finished my project, I posted a pic in another thread, but it was a junky pic, I've got more pics now. Plus I re-did the bezel, I didn't like how the first one turned out.
First had to use a heat gun and push the vent tubing back in the dash about 1 - 1.5" or so. Otherwise the deck would have set too far out. I wanted it to sit farther in but It's as far back as I could get it without completely destroying the vent tubing. That's all the dash mods you have to do. It will fit between the bottom of the vents and the ashtray "roof" without having to cut anything.
By jshultz78
Picked up a couple of bezels at a junkyard so I would have more than one chance at it.
I used my dremel to cut out the flat part on the left side of the radio, and on the right side to fill in the gap I just used a piece of abs plastic and glued it in from the back, You also have to trim out the bottom half of the "visor lip". Then I completly removed the bottom bar that runs across the bezel. I had to cut the hole for the hatch switch because all they had was s10 pickups at this yard. I had a usb mounting bracket that I found at my shop and I mounted it in the cigarette lighter since I never use it anyways. The paint is SIMS brand navy blue, It looks purple in this picture because of the flourescent lighting in my kitchen. but in the truck in sunlinght it's almost a dead ringer for the oem blue. I also had to make the front of the bezel taller, notice by my hand and on the right side also, I used to small strips of abs plastic superglued to the bottom of the bezel, otherwise there would have been about 1/4 gap between the bezel and the ashtray.
I took apart the lighter and glued the handle to the usb cable dust cover. So when not in use I can just plug the lighter back in and it looks stock.
I got bored at work today and found an old double din factory tape deck and made my own anti theft deterrent. Pulled the face off and glued the buttons back on. I used a little strip of aluminum I had laying around to make a lip for it to sit on the edge of the ashtray.
I'll get some finished shots tomorrow after the paint finishes curing tonight..
Old Dec 30, 2009 | 10:21 PM
degaine_designs's Avatar
degaine_designs is on a distinguished road
That should look pretty nice. I can't wait to see the finished product.
Old Jan 1, 2010 | 04:23 PM
jshultz78's Avatar
Finished product.
Old Jan 1, 2010 | 05:21 PM
boomtruck97's Avatar
boomtruck97 is an unknown quantity at this point
good job with the dvd mounting and trim job. i, really impressed at how clean it is too. the whole truck i mean. i can never keep mine that clean.
Old Jan 1, 2010 | 05:25 PM
jshultz78's Avatar
I just got finished detailing the truck, shampooing the carpets/seats and cleaning everything when I took the pics. I guess it's the flash on my camera that makes the bezel stand out, but in person it matches almost perfect.
Old Jan 2, 2010 | 02:03 AM
RangerG's Avatar
Looks real good. What 7" monitor is that? And how are you liking it so far?
Old Jan 2, 2010 | 08:10 AM
jshultz78's Avatar
pioneer avh-p4100dvd. I love it. great picture, I manily got it for ipod control but the dvd player is a plus on long drives. I've only had it a little less than a month, No problems so far.
Old Mar 22, 2012 | 11:40 AM
cippdogg's Avatar
cippdogg is on a distinguished road
Default Double din
Did u use a double din dash kit at all??
Old Sep 30, 2023 | 06:54 AM
Gary, Turner Audio Dezines's Avatar
Gary, Turner Audio Dezines is on a distinguished road
I know this is an old thread and I was hoping to see pics of the work but none of them are showing
msu12
Jun 14, 2019 12:33 AM
julioAKAjunior
Oct 9, 2012 11:29 AM
97Beater4WD
Feb 15, 2012 12:17 PM
Blazerx85
May 3, 2008 01:51 AM
Arthur
Mar 20, 2008 05:42 PM
