1995 s10 blazer 4 doors stock speakers question
Old Feb 27, 2019 | 06:28 AM
dbelcourt's Avatar
dbelcourt is on a distinguished road
Question 1995 s10 blazer 4 doors stock speakers question
Hi,
Pick up this blazer for the kids. It only has front passenger speaker working and a stock Delco cd HU. As far as I can tell, speaker system is 4x6.5" in doors and 2x front tweet in dash. I pulled and tested non-working drivers side door speakers and they are opened. What confused me is back one is marked 9.5 ohm and front is 4 ohm? Diagrams I've seen has tweeters in parallel with front doors. The vehicle shows signs of previous audio mods, guessing a rear amp at some point. Aside from taping into rear speaker wires, harness looks intact. I can't rull out some speakers were replaced and someone bolted in whatever they had on hand that said Delco. Can anyone tell me the impedance of the stock speakers all around? I'm planning to get 4 cheap speakers and wrap up this project quickly. Hopefully less than $50. Your help will be appreciated.
Both Delco, but front is marked 4ohm, rear 9.5ohm.
Old Mar 7, 2019 | 01:18 AM
Trukntigger's Avatar
Odd mix. You know that does not really matter. Match speakers to the radio your using. Only thing that counts is sized to fit the space your putting them into. Check wiring with simple multimeter, make sure good from speaker to radio. Hook up and let the kids enjoy. If keeping the stock radio look up on web if markings not on unit. Bench test if possible before reinstalling.
Old Mar 12, 2019 | 09:32 PM
I think they used the 9.5 in the back for a deeper sound.
edit:
the deeper sound is what creates a more surround sound, with the mids in the doors and vocals more on the dash. I need to have all my speakers working, drives me crazy when ones out, because that all I focus on, the lack of sound from that space lol...
Old Mar 12, 2019 | 09:51 PM
cleburne red's Avatar
My truck would drive you nuts, then! The rear door speakers are blown, as are the ones in the dash. All I've got are the two front door speakers!
Old Apr 3, 2019 | 08:31 PM
dbelcourt's Avatar
I ended up getting 2 pairs of cheap 4ohms. Sounds ok, for $40 worth of speakers and stock Delco head. I barely got the screws of 6.5" speakers to bite into the OEM plastic ring.
Old Apr 4, 2019 | 04:56 PM
N. Jensen's Avatar
I think the Kenwood speakers I replaced my oem with were 5.25", in all 4 doors. Then Pioneer 4x6's in the dash where the tweeters and speaker brackets were. Sounds good.
I used Crutchfield for sizes, then googled part numbers I wanted to find the cheapest price.
audiophilia
Jun 28, 2013 05:46 PM
CoffeeAddict
May 5, 2013 02:08 PM
DarkRose
Nov 10, 2011 05:38 PM
roflwaffle08
Jul 10, 2009 07:21 PM
BLK85
Apr 30, 2007 09:50 AM
