'95 (?) Blazer has Loose Antenna
Old Jun 11, 2010 | 08:25 PM
ncc74656m's Avatar
ncc74656m is on a distinguished road
Default '95 (?) Blazer has Loose Antenna
Hey all,
The antenna on this Blazer is very badly loose. That is, the base of the antenna, not the whip itself. I can't figure out how to tighten it down or anything because the antenna goes under the fender, and its location is behind some master cylinder or other.
I see two holes in the fender next to it, it looks like they were meant to hold bolts or something originally, but I have no idea if it was meant for the antenna?
Attached Thumbnails '95 (?) Blazer has Loose Antenna-img_5356-medium-.jpg   '95 (?) Blazer has Loose Antenna-img_5357-medium-.jpg
Old Jun 21, 2010 | 01:47 PM
MTopper's Avatar
i had the same problem but mine is on an '04 and i don't know if there is a difference. Can you take a picture of the inner fender location?
Old Jun 22, 2010 | 10:48 AM
ncc74656m's Avatar
Nothing doing on the picture of the inner fender. It's entirely blocked by some cylinder or other (didn't bother looking far enough back to figure out if it's the brake booster or what). I'll just see if I can rig up some other option to just pin it in place.
Old Jun 22, 2010 | 12:52 PM
MTopper's Avatar
well, literally, my problem was nothing more than the mount being loose. i tightened it from underneath with a pair of pliers and it worked. i honestly couldn't tell you what i grabbed a hold of, i just know it worked
Old Jun 22, 2010 | 01:18 PM
ncc74656m's Avatar
Yeah, that's the lousy part, it definitely looks like it should be easily tightened and I can't figure out how or where from.
Old Jun 22, 2010 | 04:02 PM
MTopper's Avatar
i reached in from the engine compartment. i had the battery out already when i was doing some maintenance and what not which freed up access for me. so you can try that and see what happens but thats up to you
Old Jun 23, 2010 | 09:14 AM
ncc74656m's Avatar
Ah, I'll have to look. As far as I could see, the battery was not in the way, but then, I haven't opened the bay in a few days. My alternative is that I can dremel out a small section of the inner fender where the antenna is and see if there's an obvious way to fix it. Not my preferred method, but definitely will work. Probably.
chevylover5
Dec 24, 2013 08:31 AM
Beckyj636
Jul 14, 2011 10:04 AM
ussexplorer
Apr 11, 2010 06:53 PM
rastoma
Nov 12, 2009 05:16 PM
johng
Jan 16, 2008 06:08 PM
