Amp firewall pass through
Old Aug 11, 2019 | 02:53 PM
Matthew Nicholas's Avatar
Matthew Nicholas is on a distinguished road
Default Amp firewall pass through
Having a hard time finding a spot to run the Power cable for amp through the firewall. I have a 2000 Blazer LS 4x4. Can anyone point me in the right direction?
Old Aug 11, 2019 | 04:14 PM
I had to run a couple of power cables in mine, and I ended up going through the floor and along the frame to the front. There just isn't a lot of room on the firewall.
I used some of
these these
to make the holes water tight.
Old Aug 12, 2019 | 06:44 AM
Depending on the gauge of wire you're trying to run, you can squeeze up to about a 4 gauge through the antenna grommet on the passenger side after you open the hole up a little. Just don't forget to seal it up with a little silicone afterwards, they're prone to leaking with just the antenna wire in it...
For my 0 gauge, I ended up running along the passenger side frame rail and came up through the floor under the rear seat via a drilled hole and a grommet I popped in place.
Ended up adding another fuse junction where it terminated under the back seat, which has worked out great because I've been able step it down to 4 gauge with some of the various amps I've had in the truck.
Old Aug 16, 2019 | 08:45 AM
LesMyer's Avatar
I took my power off the starter terminal, went through a waterproof fuse holder, and immediately went inside the frame rail to the rear - coming up through a grommet into the old Onstar module compartment where I mounted my amp. This was on a 2001 LT four door.
BRoss99
Oct 27, 2014 01:50 PM
nnnon632
Oct 9, 2011 10:32 AM
Blaze the S10 4x4 Blazer
Oct 20, 2010 09:50 AM
BlueBlazzin
Jul 21, 2006 03:28 PM
87s10blazer
Jan 20, 2006 09:16 AM
