Big Three Upgrade
Old Jun 7, 2008 | 02:30 AM
Big Frost's Avatar
Big Frost is an unknown quantity at this point
Default RE: Big Three Upgrade
ha! that too...thanks for the help! im going to go get one first thing tomorrow...see if it helps.
Old Jun 7, 2008 | 02:32 PM
willjones's Avatar
Mine only dim when I turn up the gains on my amp. It dims when my sub hits and only when it hits.
Old Jun 7, 2008 | 06:19 PM
jagblazer01's Avatar
ORIGINAL: willjones
your gain is not a volume ****....u shouldnt do that
you should probably get either a bigger battery or a second battery.........the big 3 actually did help my truck run better...you can tell it runs smoother over the stock wiring. I did my upgrade with 1/0 wire and added a 300 amp alt
Old Jun 8, 2008 | 08:12 AM
neo71665's Avatar
ORIGINAL: jagblazer01
ORIGINAL: willjones
Seemed to help mine run better also. The only alts I can find for mine are 200 amps but that should be fine. Also my big 3 was done in 4 gauge (everything still factory but I changed 99% of my bulbs to LEDs) but by the end of the day its gonna be 1/0.
DaddysBlazer
Nov 1, 2011 10:37 PM
ExplicitYourSelf
Oct 13, 2009 10:18 AM
NVANZEE
Mar 20, 2009 05:43 PM
RegSo
Jan 18, 2008 08:04 PM
Loud_01_Blazer
Oct 24, 2006 02:30 PM
