bose amp pop after deck install
Old Jan 18, 2007 | 03:52 PM
kaps's Avatar
kaps is an unknown quantity at this point
Default bose amp pop after deck install
Never popped before, it pops once at turn on and a slight pop when changing tracks on a CD only, not radio or iPod. I connected the blue amp turn-on wires correctly from Hillbillys suggestion. Using metra 21 pin harness and an Alpine CDA-9856 deck. On the metra harness bag it stated that there might be an amp ground, but there was no wire in particular harness, maybe thats it? Or I wired an additional amp lead to go to my subs I will be installing in a few minutes, the other lead is taped off so I know its not going to ground out until its installed. Any help? Google turned up that I might have to run a relay to slowly power the amp up, not sure if thats the cure or a band-aid to "fix" a problem.
The deck has an option to turn off its internal amp, it pops with it on and off.
The RCAs for the sub are the type that has the amp lead inbetween them, intereference even without it hooked up?
Not looking forward to ripping this back apart, so hopefully I can resolve this soon. Im off to hack saw my dashboard to fit the deck.
Thanks for any help!!
Old Jan 20, 2007 | 04:49 AM
kaps's Avatar
Default RE: bose amp pop after deck install
Im now also getting a cracking noise at low volume. Sounds good at higher volume.Going to look into grounding the deck directly to the frame, but the closest spot I found was under the gauge panel about 2 feet away. I got my subs in also, kinda disappointed with the output, but I will try and fine tune everything later.
If anyone else has an idea to what to do I would appreciate it.
Old Jan 20, 2007 | 07:21 AM
hillbillyinOhio's Avatar
dont use that lead on RCA's as remote lead. use it as a ground. sometimes, factory amps just dont like to play. if you have access to resistors, you couls splice a 1k ohm resistor on remote turn on lead.
unpredictable1
Oct 26, 2014 04:12 AM
wardlarson
Oct 7, 2010 10:54 PM
stevengrc
Feb 5, 2009 09:19 PM
89LX
Aug 17, 2007 04:12 PM
