Car Audio Discussion
Old Feb 13, 2011 | 05:29 PM
  #331
blazinloud's Avatar
so it powers off? did you check the wiring?
Old Feb 13, 2011 | 06:44 PM
  #332
Thogert's Avatar
Yeah, I checked the wireing and fuses. It's really strange that it powers off for about a second and then powers back up.
Old Feb 13, 2011 | 07:19 PM
  #333
MTopper's Avatar
check the wiring. you could have crossed wires or something
Old Feb 13, 2011 | 09:07 PM
  #334
ImScrewed92's Avatar
Originally Posted by blazinloud
let me get this right, your mom wants a 15? thats pretty sweet!
When I was a 15, I put two 12's and a 800 watt amp in her ford focus, you know, cause I'd be driving soon. When I got my own car and pulled the subs and amps, she started bugging me about it sounding too hi pitched like she was listening to headphones . But she listens to a lil bit of everything from rap to rock to contemporary gospel. I tell ya, "no one" by Alicia Keys was the first song to knock my radar detector off the blazers windshield, lol.
Thogert, has it always done this or did it start out of no where? I know you have checked the wiring, do you have a voltage meter to see what power it's drawing? Is it grounded through the wiring harness? For some reason I've seen some units that wouldn't ground %100 through the harness.
My cousin had installed a old 1995 Pioneer cd player in the BMW I got off him and it would do that. Cleaned every connection, redid all the wiring connections in the dash, (he cut the factory harness out and hardwired everything, I F****** HATE THAT,) and I eventually grounded the headunit to the headunit itself and never had a problem agian. Just some things I've known to help problems like that. Shutting off for a split second sounds like a ground problem to me, or power supply problem, just my 2 cents though.
Old Feb 13, 2011 | 10:03 PM
  #335
matt92's Avatar
matt92 is on a distinguished road
Im torn between 2 subs.
Alpine type R 15", or a Kicker solo baric L5 15".
Ive looked at the specs and they are the same im pretty sure. Are the square subs any better than the circles?
WHICH ONE SHOULD I GET?
Old Feb 13, 2011 | 10:41 PM
  #336
MTopper's Avatar
squares are actually worse when it comes to recreating sound waves. i'd say go with the Rs but you're also going for 15s so you're not too worried about clean sound but rather loud i assume
Last edited by MTopper; Feb 14, 2011 at 01:16 AM. Reason: dont answer questions when tired
Old Feb 13, 2011 | 10:55 PM
  #337
Thogert's Avatar
Thanks guys I'll try rewireing it and see how it goes.
Old Feb 14, 2011 | 10:04 PM
  #338
xmradioguy's Avatar
xmradioguy is an unknown quantity at this point
Originally Posted by Thogert
Hey so I've got a question for you guys, I have a kenwood deck and whenever I turn the volume up to a certain point the deck loses power and resets, do you have any ideas as to why?
I am gonna guess you have your gains cranked up all the way on your amp(s) and when you turn up your head unit after your amps are running hot and drawing all the current possible and your deck powers off and on because it's not getting the required current. Your lights probably dim too, You would likely benefit by upgrading the big 3 wiring and setting your gains properly with an o-scope or the very least do some math and set your gains with a DMM.
Old Feb 14, 2011 | 11:08 PM
  #339
Thogert's Avatar
No it turns out that the ground wire vibrated lose and was disconecting from the frame, I hadn't checked that. But thanks I appreciate the help.
Old Feb 14, 2011 | 11:51 PM
  #340
xmradioguy's Avatar
Ok I just saw you had earlier said you checked the wiring so I didn't suggest checking the ground again as I figured that was checked.
