Car Audio Discussion
Old Oct 25, 2010 | 09:08 PM
  #81
TylerCiervo's Avatar
TylerCiervo is on a distinguished road
12" P2's. And 36" is all I can fit in the back =[
And i've been looking around.. kinda feeling a few pairs of MB Quarts instead of the HiFonics Tritons..
Old Oct 25, 2010 | 10:28 PM
  #82
MTopper's Avatar
well... i guess good luck with the build. i would have gone with something else for the money but to each his own
Old Oct 25, 2010 | 11:05 PM
  #83
01vortec's Avatar
01vortec is an unknown quantity at this point
Originally Posted by MTopper
and, why such a narrow box? mine is 32 inches only because i have a spare tire in the way. if there wan't that i'd be about 40ish inches no problem
im not sure about 2drs but in a 4dr the widest box you can fit is 36 or 37" across since thats how far apart the wheel wells are
Old Oct 25, 2010 | 11:28 PM
  #84
JShark's Avatar
JShark is on a distinguished road
this dude has been talking about putting 436 rockford 12's in his space shuttle for the past month... would you just buy the subs and do it already?
Old Oct 26, 2010 | 12:37 AM
  #85
If that's directed at me you should read more..
Old Oct 26, 2010 | 01:14 AM
  #86
01vortec's Avatar
I figured since this is a discussion thread i'd throw a few vids up, none are very good though. take note this is only 900 watts, so don't expect something amazing
http://www.youtube.com/watch?v=3BelaTPY3zs
http://www.youtube.com/watch?v=wDP3Cjori34
in the last vid my damn phone kept getting texts so that's what that ringing is, and for some reason youtube turned the brightness way down from the original one so it's pretty dark.
Old Oct 26, 2010 | 08:00 AM
  #87
altoncustomtech's Avatar
Tyler, i was wondering something earlier.... How do you plan on crossing the tweeters and speakers? the 8 inch squares you have only play up to 10,000 Hz. i don't know any amps that are on the cheaper side capable of going up to 10,000 hz on their onboard crossovers.
^^He's right, you will have to crossover the speakers. Running the Tritons too high will cause BAD BAD noise problems, and running low frequencies to the tweeters will fry them fast. Try these, they're crossovers that go on the RCA inputs of the amps. Not as good as active processing at the HU or built into the amp, but good enough for what you're doing.
http://www.parts-express.com/pe/show...number=266-288
http://www.parts-express.com/pe/show...number=266-286
The low pass would be for the mids, the high pass for the tweeters.
Originally Posted by TylerCiervo
Would this be good for the Tritons?
http://www.sonicelectronix.com/item_...+HFi100.4.html
And this one for the fronts and tweets?
http://www.sonicelectronix.com/item_...s+HFi55.4.html
Both of those amps would do well for what you're wanting to do, though I would look into this one for the mids just so you have a chance at running them with as much power as you can get.
http://www.sonicelectronix.com/item_...+ZXi150.4.html
Old Oct 26, 2010 | 08:59 AM
  #88
That looks pretty good. I was considering just getting all MB Quart speakers instead of the Tritons. But we'll see.
What amp would you recommend for the subs? I have 8 12" Rockford P2's. The 4ohm versions.
Should I get 1 amp for everything. Or 2 separate amps and put 4 on each amp.
Old Oct 26, 2010 | 03:17 PM
  #89
Well, for 8 P2's you'll want around 2000 watts total RMS power since that's what they all add up to. I gotta ask though, are they Dual 4 ohm or Dual 2 ohm? I couldn't find a P2 with a Single 4 ohm coil. If they're D4 then you can get by with series/paralleling the subs together to a 1 ohm load and use a single amp. If they're D2 (or Single 4) you'll either need two separate amps OR a pair of amps that can be strapped together.
Old Oct 26, 2010 | 04:31 PM
  #90
I sent you a pm! lemme know if you got it or not.. That seems like an easier way to talk.. Haha
