Cheap subs?
Old Jan 5, 2010 | 10:09 PM
88s10Blazer's Avatar
88s10Blazer is an unknown quantity at this point
Default Cheap subs?
Just been checking around on ebay and I've got a few Sub Kits, wonder if anyone has ever head of them. Just looking for somthing that pounds pretty good.
http://cgi.ebay.com/XXX-Car-Audio-2-...item5ad21b8148
http://cgi.ebay.com/New-1000W-MTX-Ma...item2eaa2c766d
http://cgi.ebay.com/New-Car-Audio-Du...item2eaa27ed55
Anyone know of any others? Just looking for something cheap at the moment. Then later comes the FI BL12's
Old Jan 5, 2010 | 10:16 PM
ABN31B's Avatar
OMFG Dont judge me but click this
Seriously, i have a 750/5 crap amp pushing 2 of those and 4x JL 6.5"s.... those are the single most power efficient subs i have ever seen! considering they are only sharing about 300 watts of amp juice, they hit pretty damn good!
and at $50 for the pair, and a $40 subzero box, you have a set of 12's, loaded, for under 1 bill. enjoy
one day i will feed them with the jl 500/1 sitting in the garage and stack a 300/2 on the doors, but for now my little 5 chan is doing all it was intended too and more!
Old Jan 6, 2010 | 02:28 PM
boomtruck97's Avatar
boomtruck97 is an unknown quantity at this point
http://cgi.ebay.com/MTX-Car-Audio-2-...item35a6045a9c
thats one thats not bad for the price, i have installed a few of these in peoples cars and there not bad just make sure they have a good return policy as i have seen a few here and there with bad amps in the set from the factory.
also here is a combo you may like
subs
http://cgi.ebay.com/ebaymotors/1000-...sQ5fEnclosures
amp
http://cgi.ebay.com/ebaymotors/New-L...fAudioQ5fVideo
box
http://cgi.ebay.com/TWO-12-inches-DU...item3ca8eed204
i know what your all thinking. but i will tell you a friend of mine bought these and i yelled at him. then i installed it and was rather surprised indeed. its not Fi audio but it is an underground company that hasnt taken off anywhere yet. 2 subs for 40 bux.
that whole setup for 150 after shipping, plus wiring. i would suggest as a temp system, you will be impressed at what they do. or buy two of the hifonics from above and stick to it for like 10 dollars more.
Old Jan 6, 2010 | 07:36 PM
I think I'm going with this set up. How's the amp look for this?
http://cgi.ebay.com/2-PIONEER-TS-W25...item439c497ea4
http://cgi.ebay.com/SOUNDSTORM-1600-...item518d7d7e28
Old Jan 7, 2010 | 12:54 AM
with those subs i would recommend this amp.
http://cgi.ebay.com/POWER-ACOUSTIK-P...item35a4a36f07
it will push 2400 rms at 1 ohm, and its d class
i have used these amps on a lot of setups and they really do push some power. i even ran these at cruisefest on weekend. We had 4x VFL 15" subs at .5 ohm on each one and it played constant with no issues.
Old Jan 7, 2010 | 12:32 PM
Could I wire these subs up to run 2 ohms? What would be the best way to go with that amp? It looks like that amp would maybe blow them. I'm not sure because I don't know a whole lot. Just want the subs and amp to be paired perfectly.
Old Jan 7, 2010 | 09:11 PM
01vortec's Avatar
01vortec is an unknown quantity at this point
that amp would be lucky to do a true 900wrms. it's fused to 90 amps, at a perfect 14.4v it would do 1296watts before it pops the fuses for drawing too many amps. but then you have to factor in efficiency which is probably 70-80% at best, even lower on cheaper amps... figure 75% is 972 watts, and not many people are gonna keep a steady 14.4v so it's going to be even less.
Old Jan 9, 2010 | 01:31 PM
either way, i think it would be a better choice then the soundstorm amp and its all temp anyhow. which of the two would you run? or do you have a better choice for the money?
thrash902
Jan 28, 2010 06:58 PM
88s10Blazer
Jul 18, 2006 04:07 PM
88s10Blazer
Jun 19, 2006 06:50 AM
Freekstile
Aug 19, 2005 04:40 PM
dobbist
May 22, 2005 04:48 AM
