Connecting passive subwoofer
Old Mar 18, 2008 | 04:16 PM
magnum434's Avatar
magnum434 is an unknown quantity at this point
Default Connecting passive subwoofer
Hey,
I haven't been on here a while since I sold my Blazer but now my friend has one and wants to connect a non-powered sub to his head unit. On the back of the head unit, there is a left and right rear audio output and on the sub there is just the + and - terminals. How do I connect this? Do I tap into the 2 wires on the back of the rear door speakers and go from there?
Old Mar 18, 2008 | 04:17 PM
magnum434's Avatar
Default RE: Connecting passive subwoofer
I guess I should have posted this in the electronics forum thing. Should I move it? Or can a mod do it for me? Sorry.
Old Mar 18, 2008 | 04:39 PM
*Moving to Audio/Visual Electronics*
Old Mar 18, 2008 | 06:37 PM
cloak01ls's Avatar
cloak01ls is an unknown quantity at this point
What model head unit id your friend running at what is the impedance of the subwoofer. On some pioneers you can bridge the rear channels at a 4ohm load and switch the rear spekers to sub frequencies. If your head unit doesnt allow this than without some sort of crossover you will be sending a full range signal to your sub, which wouldnt be good for it...also, unless its a small sub with a high sensitivity you arent going to get much out of it. The bridged rear channels put out around 30-50wrms total depending on the head unit...
Old Mar 18, 2008 | 06:55 PM
bobditts's Avatar
bobditts is an unknown quantity at this point
hold up!!! you want to power a sub from the Head units built in amp???? what sub is it?
Old Mar 18, 2008 | 08:09 PM
magnum434's Avatar
It's just some old piece of **** thing from like...50 years ago. Ha. He's bound and determined to get it in and I'm going through a breakup and just trying to stay busy.
Old Mar 18, 2008 | 09:15 PM
bobditts's Avatar
well he might blow his HU up in the process if he doesnt know what hes doing. MOST head units can NOT be bridged so dont let him do that.
Old Mar 18, 2008 | 09:34 PM
dbleon's Avatar
dbleon is an unknown quantity at this point
Just buy a cheap/ used amp on ebay... You should be able to get one for under 50.
bmrdoc
Jan 11, 2014 09:45 AM
JRob238
Mar 20, 2011 04:46 PM
denver jimmy
Oct 4, 2010 12:56 AM
rknight
Jul 23, 2010 07:19 PM
randallsblazen
Mar 9, 2009 10:45 PM
