Dash lights out after stereo install
Old Dec 26, 2009 | 10:14 AM
robrote's Avatar
robrote is on a distinguished road
Default Dash lights out after stereo install
I recently installed an aftermarket stereo in my 99 blazer 4X4. About an hour after hooking it up, the dash lights went out. I replaced the headlight switch and shortly after, the dash lights went out again.
I did not hook up the orange or orange/white wires on the head unit. The factory harness was in good shape and uncut. I used a aftermarket connector to hook the h/u up. I'm stumped. What could be frying the dimmer switch? No fuse issues found.
Old Dec 26, 2009 | 10:42 AM
jacobcnc's Avatar
jacobcnc is on a distinguished road
What else happens does you stereo shut off? When the dash lights go out
Old Dec 26, 2009 | 10:43 AM
cbr995's Avatar
I had a similar problem. Did you check if the wires were all plugged in behind the dimmer switch?
Old Dec 26, 2009 | 10:56 AM
robrote's Avatar
Just the dash lights go out. It is shorting something in the dimmer mechanism. Yes Matt, all connectors are plugged in. Only a single connector on the switch. No fog lights on this Blazer.
Old Dec 26, 2009 | 09:45 PM
jshultz78's Avatar
jshultz78 is on a distinguished road
make sure you illumination wire on the aftermarket harness is taped/capped off, if not it may be grounding out, normally it would pop a fuse but I've seen them burn up switches before.
Old Jan 4, 2010 | 02:06 PM
robrote's Avatar
Update--I think it's fixed. I did not snap off the dimmer wire from the aftermarket harness so its possible it was grounding out on the stereo mounting cage (thanks jshultz). Also, I didn't trust the ground that is part of the harness so I ran a ground from the back of the stereo to the body.
All seems good now. It cost me two used switches (and one fuse), but found them on ebay cheap.
DEATH-TRAP
Feb 26, 2012 05:32 PM
FancisMH
May 24, 2011 01:43 PM
Klone
Feb 19, 2011 06:34 PM
crazyjust
Apr 5, 2010 10:35 PM
vagnozzi
Mar 18, 2007 08:51 PM
