factory cd players
Old Feb 8, 2008 | 08:04 PM
magtec's Avatar
magtec is an unknown quantity at this point
Default factory cd players
i'm looking for a factory cd player that will drop into my '97 blazer.
what years/models are compatible?
any suggestions as to what i should look for or what i should stay away from?
Old Feb 8, 2008 | 08:22 PM
Tippman7641's Avatar
Tippman7641 is an unknown quantity at this point
Default RE: factory cd players
i got one from a 2000, dont knwo if itll work, its in pristine condtion
Old Feb 8, 2008 | 08:39 PM
hillbillyinOhio's Avatar
well, a 95-97 will work perfectly. the problem you are going to run into if you try to go 98 and newer is the mounting is totally different. On your truck, you have the pocket below the radio, with 2 screws on top of the radio and two below the pocket, the 98 newer have mounting on the sides. You would be better off finding a nicer cheap aftermarket deck to put in it. Try the JVC kdg-320 (older model kdg-230), pioneer Deh2000MP, (r older model deh1900mp).
You will need a few parts for that install though, antenna adaptor, wiring harness and dash kit.
Best bet would be to buy a radio from crutchfield, as they will throw in the parts for free if you buy a deck over 130 i think.
But the parts are as follows( all metra part numbers)
40-GM10, (antenna) 70-1858 (wiring harness) and 99-3044 (dash kit).
Im also moving this to the A/V section. you can read my sticky at the top of the page for some other model numbers (here)
Old Feb 9, 2008 | 07:08 AM
magtec's Avatar
the truck currently has an aftermarket head unit installed. to put it nicely, the new owner (my mother) does not understand how to operate most aftermarket radios, so i'd like to replace the aftermarket head unit with a factory cd player.
02Goldie_Loks
Tires and Wheels
Aug 11, 2015 06:49 PM
SWANNERZ
Aug 13, 2014 05:05 PM
S10Blazer
Oct 31, 2006 08:12 AM
TheDesertFox
Aug 3, 2006 04:55 AM
K5Carnage
Jun 6, 2005 08:22 PM
