This f'n switch!!!
Old Jan 15, 2008 | 08:20 PM
EuroGoldLS's Avatar
EuroGoldLS is on a distinguished road
Default This f'n switch!!!
I bought a toggle switch at autozone. Albeit a cheap one, it is billet and has a blue led on the end of the switch shaft. I mounted the switch. No problems there. I hooked the foglights to it ground and power,jumped theACC prong to the gauge power so the switch would come on with the headlights, flipped the switch... LED comes on and foglights don't, but my parking lights came on.... figuring out that by jumping the ACC on the switch to the gauges....well I made a mistake... I went back and swiched everything. Same deal, except when I turned the parking lights on, the foglights came on as well. Fixed that tooby unhooking the ACC wire, then nothing would work. Finally I figured out that the ACC and Power were marked incorrectly. So if you buy a Pilot Billet Azure LED Toggle switch, be warned that the stickers may be backward.
Anyway. Does anyone know of somewhere I can piggyback the LED to make it come on only when the vehicle is on or only when the switch is on? Preferably on the left side of the vehicle. I have the switch mounted on the headlight panel.
Old Jan 15, 2008 | 08:24 PM
cloak01ls's Avatar
cloak01ls is an unknown quantity at this point
Default RE: This f'n switch!!!
if its a three prong LED toggle it should be a very simple wire up...
+12v - Constant 12v Power
ACC - To fog lights
GND - To Ground
This config should turn on your fog lights with the switch, and the LED should only come on when the lights are switched on...
The labels on these switches are a little akward. They make sense but they dont correspond with your everyday 12v addons. The PWR and ACC are basically your loop. take your hot wire for what you are wanting to turn on and cut it. Hook up the power souce side to the PWR prong, and the side going to the component to the ACC prong. The Ground prong is only there for the LED and is not necessary...
Old Jan 15, 2008 | 08:48 PM
blznlowxtreme's Avatar
blznlowxtreme is an unknown quantity at this point
^^^agree completely^^^
Old Jan 15, 2008 | 09:08 PM
EuroGoldLS's Avatar
Ahhh. so I can connect the Power side to a constant source... ok. gotcha. I'll definately get that tomorrow. Its my DD so I look forward to tearing out the dash again Thanks a lot Nick!
88Chevy
Jun 21, 2012 11:53 AM
madmack4
May 24, 2012 12:59 PM
cide
Nov 8, 2010 08:17 PM
JohninMass
Nov 28, 2009 09:14 PM
JediKnight2
Sep 11, 2008 07:58 PM
