Front door aftermarket installation??
Old Aug 7, 2013 | 06:23 PM
Kshaw's Avatar
Kshaw is on a distinguished road
Default Front door aftermarket installation??
I have a 2000 chevy blazer 4 door, no bose or anything. I'm replacing the stock speakers in all four doors. The rear speakers were easy to install and work great, however the front doors have a clip that connects into the factory speaker. Is there some kind of adapter I need to buy to install the aftermarket speakers?
Old Aug 7, 2013 | 07:10 PM
Horton's Avatar
Horton is on a distinguished road
I don't know about the clip, but assuming there are only two wires coming from the car side into that clip, and two going out the other side of the clip, you could just cut it out completely and wire (+ to +) and ( - to - ) use some wire connectors or ghetto electrical tape and voila !
That would be the simple thing, like I said, ASSUMING there are only two wires on each side of said clip. If you do go this route, leave a couple inches of wire on either side of the clip, just in case you need to re-attach it for any reason.
Old Aug 7, 2013 | 10:49 PM
richphotos's Avatar
If it not bose. Even if it was there should be only 2 wires. One positive one negative. Cut off the clip
A google search will quickly find you the radio wiring diagram to find out which wire is which
Old Aug 8, 2013 | 03:50 AM
Thogert's Avatar
The rears don't have the clip? That's weird. My cobalt has clips on all 4, not that they're used.
The wires are probably green, grey, purple, or white for both wires. One wire on both sides should have a stripe in it, probably black. That's your - and the one without the stripe is +
Old Aug 8, 2013 | 01:31 PM
Kshaw's Avatar
Thanks guys. Managed to figure it out. dumb mistake on my part haha
Old Aug 8, 2013 | 11:32 PM
richphotos's Avatar
Glad you got it figured out. Its pretty simple, the only reason for those clips is for easier installation for the factory LOL
Old Aug 9, 2013 | 09:52 AM
Kshaw's Avatar
I'm honestly embarrassed to admit what I had done wrong.. lol. I'm pretty good with stereo equipment (or so I thought). But when I had only the back speakers installed I had the fade set to rear, so when I installed the front no music came out. So instead of figuring out what had gone wrong I got frustrated and packed up for the day haha
Old Aug 9, 2013 | 05:14 PM
richphotos's Avatar
LMFAO it happens to the best of us
Old Aug 9, 2013 | 09:24 PM
Thogert's Avatar
I do the same thing all the time. You do all the work, and it gives you problems when you're done. I usually find new dents somewhere when I don't walk away at times like that.
TomCat4680
Oct 12, 2019 01:00 PM
DreezyBeezy
Jun 2, 2013 03:45 PM
scosentino88
Jun 3, 2012 07:12 PM
swe007
Mar 23, 2011 11:13 PM
Redlegger
Feb 16, 2011 01:34 PM
