just got me stuff installed!!!
Old Jan 21, 2006 | 11:18 PM
HCCAFan's Avatar
HCCAFan is an unknown quantity at this point
Default RE: just got me stuff installed!!!
I think the shop is full of ****. Eclipse has been the best company to me hands down. I have had issues with 2-3 of their decks but the audio shop I dealt with always sent it in, and Eclipse always sent me back the next better model. It has been probably 4-5 years since my last exchange so maybe they have changed their ways but that is a big reason I stick with Eclipse.
As far as your RPM dependant noise....try unplugging just your ground cable. I have a feeling your amp will stay on and continue to play, though it will sound ****ty and don't do this at any kind of volume or for a long time. This means you have a ground loop. If it cuts off when you do this test, send the amp back because it most likely has a cold solder somewhere on the board. Did you get it new?
Old Jan 22, 2006 | 12:12 AM
4lowlife's Avatar
I had similiar problem. After checking all power cables again, I found that my Fosgate RCA wire had a bad male end behing my head unit. I cut it out and spliced another male on. I wasn't going to replace an 18' wire buried under carpet and sh%t.
How about some capacitors and an isolator for another battery?
Old Jan 22, 2006 | 05:15 AM
FatRyan's Avatar
FatRyan is an unknown quantity at this point
ORIGINAL: HCCAFan
lol, if i take out the ground wire, the amp should NOT be on. if it is i got a big problem. amp is used, from some1 at CA.com. i dont think its the amp. theres prolly a load in the ground. i havent really messed with the ground too much to try to fix it yet though.
Old Jan 22, 2006 | 05:18 AM
FatRyan's Avatar
ORIGINAL: 4lowlife
its not the rcas. and a cap doesnt have anything to do with defeating the noise. its not really that bad anymore so im not bothering with it unless i got alot of time
btmbass
Sep 28, 2011 10:49 AM
sporty_drew
Lifting Tech
Oct 12, 2009 09:38 AM
rabbit0102030
May 17, 2007 10:26 AM
davtak
May 17, 2007 12:24 AM
ivannj
Nov 28, 2005 09:43 PM
