keyless entry is it equipped or not
You may already have the RKE (Remote Keyless Entry) module installed. It should be located above the DLC (Data Link Connector). If you have RPO code AU0 (A U Zero), then you already have the RKE module and a previous owner must have lost the remotes (check inside the glove box). If you do not have RPO AU0, then look around in the junkyards for a blazer with it, and pull the RKE module and possibly 1-2 ft of wire after the electrical connection to the RKE module. I believe that if you have power locks, the RKE wiring is there, but I have been wrong before.
Here are two threads on this subject (search function works...):
keyless entry fob
Adding Keyless Entry
Good luck and let us know if you need any more information.
keyless entry fob
IIRC my truck has remote keyless entry, but still has a keyhole in the back. But could be because my truck is an older model, I'm not too familiar with the newer models....yet.
ExplicitYourSelf
Jun 5, 2009 08:40 PM
yjmopar
Apr 29, 2009 11:37 AM
