keyless entry is it equipped or not
Old Mar 6, 2007 | 11:56 PM
robert's Avatar
robert is an unknown quantity at this point
Default keyless entry is it equipped or not
recently purchaced a 2000 blazer previous owner only gave dealer the 2 keys no remotes how can you tell if this vehicle is equipped with this option
Old Mar 7, 2007 | 01:03 AM
bgillette78's Avatar
bgillette78 is an unknown quantity at this point
Default RE: keyless entry is it equipped or not
if you look at the rear hatch button. if it has no key hole then it is equipped and if it does then it usually is not
Old Mar 7, 2007 | 04:51 AM
aspenpup's Avatar
aspenpup is an unknown quantity at this point
eBay has a bunch of people who sell replacement remotes. There is a procedure to sync the new remote to your car.
Old Mar 7, 2007 | 09:35 AM
You may already have the RKE (Remote Keyless Entry) module installed. It should be located above the DLC (Data Link Connector). If you have RPO code AU0 (A U Zero), then you already have the RKE module and a previous owner must have lost the remotes (check inside the glove box). If you do not have RPO AU0, then look around in the junkyards for a blazer with it, and pull the RKE module and possibly 1-2 ft of wire after the electrical connection to the RKE module. I believe that if you have power locks, the RKE wiring is there, but I have been wrong before.
Here are two threads on this subject (search function works...):
keyless entry fob
Adding Keyless Entry
Good luck and let us know if you need any more information.
Old Mar 7, 2007 | 04:26 PM
BobTheBlazer's Avatar
BobTheBlazer will become famous soon enough
IIRC my truck has remote keyless entry, but still has a keyhole in the back. But could be because my truck is an older model, I'm not too familiar with the newer models....yet.
Old Apr 12, 2007 | 10:46 PM
mike31503's Avatar
mike31503 is an unknown quantity at this point
In all the numbers in the glovebox I see AU0..... So I guess that means yes. Where is RKE module located in my 1995 4dr blazer....? Thanks ahead
Old Apr 19, 2007 | 05:05 PM
kerander's Avatar
kerander is an unknown quantity at this point
see my post on RKE in the diy section
Old Apr 21, 2007 | 12:45 AM
getonerd's Avatar
getonerd is an unknown quantity at this point
is anyway that i can check it
some numbers in the glove box been faded
1GNCS18W12K105182
nitehawk3600
Jun 23, 2014 08:47 PM
John C
Nov 17, 2013 07:28 AM
ExplicitYourSelf
Jun 5, 2009 08:40 PM
yjmopar
Apr 29, 2009 11:37 AM
Thrty5thsc
15
Jun 28, 2005 01:40 PM
