Need ideas on enclosure...
Old Dec 10, 2007 | 11:11 PM
dbleon's Avatar
dbleon is an unknown quantity at this point
Default Need ideas on enclosure...
I dont haveany problems fabricating, butI need ideas for an enclosure. 89s10 blazer 2 door. I want to put two tens, and I have two amps... I just have no idea where to hide the amps. Should I build them into the box, or does anyone have any trick spots in these blazers? The amps are pretty big, a 4 channel and a mono Planet audio... The subs dont need much airspace (Kappa perfects).. but the amps are killing me! Help please!
Old Dec 10, 2007 | 11:21 PM
hillbillyinOhio's Avatar
Default RE: Need ideas on enclosure...
what is the width of the two end to end?? I would look at making a drawer underneath the subs. you can make it a lil larger and run the wires up through the bottom of the box to hid them after they get past the back seats. just leave a little slack in them and they will be fine. That is my first thought. let me sleep on it.
Are you planning on running them sealed (I would suggest that) or ported? Infinity subs just seem to do better in smaller sealed boxes. Although the Fs is relatively low, i still would go sealed. they tend to over exert at higher volume when lots of power is added. I would look to about .5 cubes per sub after disp. I will see what I can whip up tomorrow night and pm you some ideas.
Old Dec 10, 2007 | 11:34 PM
dbleon's Avatar
Ya I'm def. going sealed... The drawer idea is good... I have to think about it....I'm just getting frustrated with the lack of space. I was thinking of doing a wrap around with the subs behind the seat and then amp racksin front of the wheel wells... but that takes up alot of space. Now that I think of it a low profile up firing system with a false floor covering everything would be trick. Just dont know how the subs would sound under a false floor. Or if the amps would get enough air... What do you think?
Old Dec 13, 2007 | 06:49 PM
blazinloud's Avatar
do I smell a blow through
Old Dec 13, 2007 | 07:36 PM
bobditts's Avatar
bobditts is an unknown quantity at this point
can you fit the amps under the rear seat?
Old Dec 13, 2007 | 08:38 PM
cloak01ls's Avatar
cloak01ls is an unknown quantity at this point
ORIGINAL: blazinloud
Blow-Through in an SUV eh? Thats a new one...
Old Dec 13, 2007 | 08:52 PM
bobditts's Avatar
ORIGINAL: cloak01ls
haha I was thinking the exact same thing!
Old Dec 23, 2007 | 11:23 AM
blazinloud's Avatar
oops, my bad
but he did say putting them under the false floor.
richphotos
Nov 14, 2012 01:06 PM
97cherryblazer
Jul 18, 2012 10:10 AM
BlazerGuy2001
Nov 21, 2009 06:06 PM
NickoDaFsh
Dec 7, 2008 12:35 PM
XBlazer01
Aug 28, 2006 07:00 PM
