Need new speakers
Old Oct 6, 2006 | 12:59 AM
kornphlake's Avatar
kornphlake is an unknown quantity at this point
Default RE: Need new speakers
If you were satisfied with the stock speakers I'd think just about anything should be an upgrade.
I'm kicking around the idea of Tang Band 6.5" subs. I like the idea of having a small box and from the 2 reviews I've actually found they seem to be adequate for an entry-mid level system. For ~$40 it's kind of hard to be dissapointed, plus they are small enough that you don't need a 2000W amp to run them so you can save money on an amp too.
Old Oct 12, 2006 | 02:38 PM
a_tack's Avatar
a_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud of
Check out the kicker comp-vr and the solo baric L7..... I have a buddy running 200 watts to 2 10" comp vr's and it sounds almost as good as my 1500watt system. . . The comp vr also comes in an 8" sub. . . If you are willing to spend a bit of extra money, look at the solo baric L7. . .these 8" squares put out an unbelievable sound for a small sub....
http://www.kicker.com/06/kicker_home.html
Old Oct 12, 2006 | 10:57 PM
DetroitMuscle's Avatar
DetroitMuscle is an unknown quantity at this point
ORIGINAL: a_tack
I was thinking more like a 6.5" driver to an 8" sub able to be surface mounted in the cargo area. I cant have anything that needs its own enclosure, not even a bazooka tube thing. I would even consider mounting it in the panel that hides the seat gap in the back when its folded down, I can cut the metal easy( plasma cutter on hand) so fabbin some stuff isnt a problem. I appreciate the insight but thats not what im looking for,man.
matt92
Jun 10, 2011 09:11 AM
mpett1
Aug 7, 2010 07:47 AM
JRob238
Jan 1, 2010 07:15 PM
Canadian88
Feb 23, 2006 12:55 AM
1BlazR
Jan 20, 2006 10:00 AM
