New Install Question
Old Apr 23, 2009 | 12:44 AM
Blazer_boy's Avatar
Blazer_boy is an unknown quantity at this point
Default New Install Question
Hey Guys,
Okay so I'm currently installing a Stereo i previously removed from my 1997 Sun fire.
When removing it i did not take note on how the system came out.
Now I'm working on putting the system in my Blazer. First of All, what is the best place to use as a ground, in my sun fire it was just bolted into the body, can i use a seat mount or is there a better alternative, secondly it seems to me that there should be a ground wire from the battery to the amp. As this was not the case in the sun fire, will the ground to body, work just as well?.
Any Help is Appreciated.
Thanks
Old Apr 23, 2009 | 01:18 AM
boomtruck97's Avatar
boomtruck97 is an unknown quantity at this point
a ground to the body is ideal, since you want the cable to be less than 18 inches (about a foot really) just make sure you scrape the paint and undercoating off for bare metal contact and get a good self tapper then let loose. to prevent rust i suggest a small spray of rattle can primer if you are really worried about the rust. i never got any though.
just to add on - you might want to go ahead and do a BIG 3 upgrade just to help the system a bit. its a cheap way to help a lot.
Old Apr 23, 2009 | 06:36 AM
bobditts's Avatar
bobditts is an unknown quantity at this point
actually, a ground to the FRAME is ideal. BUT a ground to the body will work almost just as well as long as the body is grounded well to the frame.
Old Apr 23, 2009 | 11:09 AM
jagblazer01's Avatar
yea if you ground your amp to the seatbelt bolt on the rear seats you will be fine
Old Apr 24, 2009 | 08:21 AM
Blazer_boy's Avatar
Awesome Thanks Guys, What Exactly is the BIG 3 upgrade and what would it do for my system?
Old Jun 9, 2009 | 08:49 AM
jah963's Avatar
jah963 is an unknown quantity at this point
Looks like a good project truck. No rust, body looks sound. Good luck!
Old Jun 9, 2009 | 02:17 PM
ABN31B's Avatar
Looks like she has a lot of potential. g/l and keep us posted
LuvMyTJ
Oct 30, 2009 08:45 PM
blazerscooby
Mar 17, 2007 06:59 PM
burns
Mar 2, 2007 01:52 AM
schmatty
Feb 20, 2007 03:44 AM
Newfiezedder
May 13, 2006 05:42 PM
