One sub hitting harder
Old Oct 2, 2010 | 07:22 PM
  #21
JShark's Avatar
JShark is on a distinguished road
Originally Posted by MTopper
JShark for the mfw.
WHOOOOOO!! tell me what i won bob, (price is right, bob barker... i know your name isnt bob ) tell me what i won!
Old Oct 6, 2010 | 06:52 PM
  #22
alpinesubs's Avatar
alpinesubs is on a distinguished road
ok, wire the jumpers on the subs so that each is presenting a 4 ohm load and then wire the actual sub in parallel. Positive from sub to positive of other, negative to negative and back to box. there is your 2 ohm load.
OR, wire each sub parallel to present 2 1 ohm loads, then you wire in series which is probably easier. Positive from terminal to positive on one sub, negative from 1st sub to positive of second sub, negative of 2nd sub back to terminal of box and you're good.
Alright I tried the second wire option and wired 2 1ohm loads and.... they are both performing very nicely. They are slightly louder and both have the same excursion, also the voltage drop is not nearly as bad as before so I must have had something wired wrong. Thanks to everyone for the help
Old Oct 10, 2010 | 12:21 PM
  #23
JShark's Avatar
because i helped i have one request, i think we would all like to see your setup.
Old Oct 10, 2010 | 07:58 PM
  #24
zerepdivad's Avatar
zerepdivad is on a distinguished road
Why are you running an amp that puts out 1000 rms with 8awg wire?
Old Oct 10, 2010 | 08:25 PM
  #25
MTopper's Avatar
i thought he meant he wired the subs with 8 gauge not the amp.
anyways... i agree, we need the setup pictures
Old Oct 10, 2010 | 08:28 PM
  #26
zerepdivad's Avatar
8 awg is WAY overkill if it's from the amp to the sub. But i have a feeling he's running 8 awg for power and ground...
Old Oct 10, 2010 | 09:25 PM
  #27
MTopper's Avatar
i would use 8 guage to my sub if i had some spare laying around. right now i have 12 gauge because its what i had. it also leaves room to grow
ussexplorer
13
Jun 2, 2015 03:04 PM
96jimmyslt4x4
Oct 5, 2011 04:16 PM
Chriscursle81
Lowering Tech
Oct 14, 2009 06:30 PM
ceanern
Nov 22, 2006 05:40 AM
blazergirl15
Jul 9, 2005 03:26 AM
