peping tom
Some thieves see tinted windows as a very big bullseye for valuable equipment within. Just a thought to consider.
If I was worried about getting my subs stolen, I would bolt them down using a different screw on each side that would require a different wrench on each so its that much harder to take, a quality alarm system, and a cover to cover them when not driving if I felt it was really necessary. What's a cover alone gonna do? Bass usually makes noise and attracts attention anyway, right? The way I see it, if someone really wants to steal your subs, they're gonna get your subs if they try hard and long enough so why not take all necessary precautions instead of one?
What I would honestly do and it would take more to do it is make your box not look like a sub box at all. Take a piece of mdf ( sub box wood) carpet it the same as your box but make it a cover plate to cover your subs, then take hinges and drill them in visibly, voila looks more like a tool storage box then a sub box!! Just an idea for you to also consider!!
ORIGINAL: otnietdehoooo
idk if the two doors have it but like tonkpils, mine already has a cover that stretches across from the drivers side over to the passenger side.
depending on what you use, it could rattle a ton. my stock cargo cover is held on with plastic tabs and washer things that are broken and it is BY FAR the most annoying thing in my truck. it rattles while idling. i have tried countless times to stop it but it comes back after a few days anyway
i did the same thing but the plastic cracks, most of the rattling is coming from the very back of the car on the cover. theres a plastic thing near the brake light and the whole plastic pillar movesand squeaks. im gonna try and drill some holes and do try to bolt it down again. its hard to explain what it did but the plastic cracked in a way where a bolt wont really help all that much
