power inverter wtf
Old Apr 21, 2010 | 01:13 AM
jaybird33081's Avatar
jaybird33081 is on a distinguished road
Default power inverter wtf
Ok guys I was wondering if someone could tell me what I did wrong. I hooked up an 800w. 400w continuous cobra power inverter to run my laptop. I hooked it to the battery then grounded it to the bolt on the front seat. When i plug my laptop into it I get the warning beep and it cuts out. I had it came with a cig lighter plug in adapter and when I used that the red fault light would kinda "fizzle" in and out but it never beeped. I used 10 gauge wire, and an 30amp inline fuse for it. I cant believe that the laptop is to much for it. So maybe just a crappy inverter? Does my wiring sound faulty? Bad ground maybe? Any ideas would be helpful.
Thanks guys
Old Apr 21, 2010 | 02:07 AM
ohsofly's Avatar
Is there a wattage rating on the power pack for your laptop? 400w is not that much and the laptop might pull more than that. Did you try your cell phone charger?
I like to ground stuff like that back to the battery with another wire just like the power wire instead of finding a bolt somewhere.
Old Apr 21, 2010 | 07:52 AM
Did the inverter come with any documentation? Troubleshooting?
Old Apr 21, 2010 | 07:55 AM
It did come with some very basic troubleshooting. Nothing that really helps. I gonna try to ground it out somewhere else and see if that makes a diff. That is the only thing i can really think of.
Did you clean the ground point down to nice clean metal before sandwiching the ground wire into it?
Old Apr 21, 2010 | 08:00 AM
Yep, I used steel wool on the bolt.
Old Apr 21, 2010 | 08:02 AM
If you have a DMM, measure the resistance on the ground wire to a known good ground.
Old Apr 21, 2010 | 05:27 PM
radiokid's Avatar
radiokid is on a distinguished road
Measure the resistance between the battery's negative post and the chassis of the truck you should have 0 resistance.
800watt with 10guage wire is a little small. try 8 gauge or even 0 gauge and run every thing to your battery.
I run a 1500 watt liner amplifier for amateur radio and use -0 gauge, with three Optima battery's hooked to a isolator, and it tends to heat up after only a few minutes of transmitting.
Make sure your not cheeping out on the battery connections, a little bit of corrosion will add resistance, cutting your power down.
Old Apr 22, 2010 | 01:07 AM
I was going to use 8 gauge but autozone didnt have any. I figured the 10 would be just fine. I took it out of the footwell and hooked it right to the battery pos and neg and it worked fine so it has to be the ground.
mcatnova
May 14, 2010 09:55 AM
NVANZEE
Feb 1, 2009 05:46 PM
EuroGoldLS
26
Jan 29, 2009 09:32 PM
ryacu
May 3, 2006 11:28 AM
