Problems with Digital Volt Meter.
Old Jul 5, 2008 | 01:55 AM
S10Blazer's Avatar
S10Blazer is an unknown quantity at this point
Default Problems with Digital Volt Meter.
Hello, I had my digital volt meter installed in a gauge pod, and when it was first installed, it was wired to my fuse box, with a "Little Fuse" add a line. The gauge was working fine, the only problem was that it was not giving an accurate reading. The normal voltage without having any accesories on, was about 13.8 volts. The real voltage at my battery was 14 and higher. So recently, I had someone wire it directly to the ignition, but I don't know exactly how. Now, the voltage reading on the gauge is lower than ever. It normally reads about 13.4-13.5, and it gets even worse when I run accesories. Does anyone know how to wire this gauge correctly, so that it gives an accurate reading? I thought about having it wired to the battery, but then I know it will always be on. I have also heard about having it wired with a switch to the battery, but I still don't think that is the right way. Please let me know if you have any ideas.
Old Jul 5, 2008 | 02:43 AM
NoPh33rRaCiNg's Avatar
NoPh33rRaCiNg is an unknown quantity at this point
Default RE: Problems with Digital Volt Meter.
i ran mine straight to my amps in the back
Old Jul 5, 2008 | 02:55 AM
S10Blazer's Avatar
That sounds good, but I think that it would turn off when I turn off my radio, wouldn't it?
Old Jul 5, 2008 | 11:41 AM
Blazin_Jason's Avatar
Sometimes you have to have the meter calibrated or adjusted.
Old Jul 6, 2008 | 03:04 AM
ORIGINAL: S10Blazer
yea
Old Jul 7, 2008 | 10:13 AM
eshballa5's Avatar
eshballa5 is an unknown quantity at this point
you may have to small of wire ran to the place your trying to read. sometimes too small of wire will create a voltage drop and you can get an inaccurate reading. Maybe try a larger dia wire. You could wire it with a switch to the battery but the switch will also create a small voltage drop.
Old Jul 7, 2008 | 06:09 PM
S10Blazer's Avatar
Ok, thanks guys. Now at least I have some options to play around with, to see which gives the best reading.
Old Jul 8, 2008 | 12:12 AM
splblazer's Avatar
splblazer is an unknown quantity at this point
when it comes to electral problems always check the ground first. wire diameter shouldnt affect it because it pulls very little amperage. try another 12v accessory spot in the fuse box see if the reading is diffrent or just connect it straight to the battery to see if the reading is the same as a hand held volt meter. hope this helps:P
Old Jul 8, 2008 | 12:32 PM
S10Blazer's Avatar
Yea, I know. I'm gonna run a few tests by running the wire to the battery, on the outside of the truck, and if that works, I'll just put a switch on it. If that doesn't work, then I'll try running it directly to the amplifier on my sound system. Thanks.
[IMG]local://upfiles/3653/F60C81FFB9964FB69C99C10C07CC97E7.jpg[/IMG]
dman001948
Nov 11, 2014 12:10 PM
chris015
Jul 31, 2011 12:32 AM
sebringflyer
Mar 8, 2010 08:31 PM
Puffie40
Nov 17, 2009 01:20 PM
zombiewoof
Feb 25, 2008 06:51 PM
