question
Old Dec 6, 2007 | 01:32 PM
AtreyuManiac's Avatar
AtreyuManiac is an unknown quantity at this point
Default question
i have posted a lot on here lately and i want to quickly throw out a huge thanks to everyone
ok but heres the question
alpine type r 12" sub
alpine mrp-m450
im told to wire the sub at a 2ohm load so it can take 400watts from the amp
do i need to do that if the subs already a 2ohm sub not a 4ohm sub?
because theres a guy selling a 2ohm type r in a qlogic ported box for 110
Old Dec 6, 2007 | 01:39 PM
mdehoogh's Avatar
Default RE: question
im sure one of the pro's on here will be able to say for sure but i thought a 2ohm sub would be either 1ohm or 4ohm depending on the way you wire it. my amp puts out power at 2ohms so i bought a 4ohm sub that way, when i wire it up it will recieve all 750w instead of just 400w
Option 1 (parallel) = 1 ohm load
Voice coils wired in parallel
Recommended Amplifier: Stable at 1 ohm mono
Option 2 (series) = 4 ohm load
Voice coils wired in series
Recommended Amplifier: Stable at 4, 2, or 1 ohm mono
Old Dec 6, 2007 | 01:53 PM
blazinloud's Avatar
did they make them with single voice coils?
find out if its a dual 2 ohm or a dual 4 ohm
Old Dec 6, 2007 | 04:10 PM
what does it mean when an amp doesnt come with its high-level input harness or 2 end caps
Old Dec 6, 2007 | 06:05 PM
hillbillyinOhio's Avatar
end caps are purely comsmetic. will hide the wiring some. and the high level input is the plug that will let you get signal from the speaker wires behind the radio instead of RCA's (if you have a factory HU
Old Dec 6, 2007 | 06:54 PM
so if i have rcas on my deck since its an alpine i dont need the input harness?
Old Dec 6, 2007 | 07:11 PM
what gauge would i use to wire the mrp-m450 amp
whats a good kit
what settings would i use frequency and all that
im a "noob"
i need all the help i can get
but im learning!
Old Dec 6, 2007 | 08:58 PM
jagblazer01's Avatar
just get a 4ga. kit. should be plenty. Stinger makes very nice amp kits.
2001Blue
Lifting Tech
Jan 1, 2011 07:15 PM
98Ltblazer
Apr 11, 2010 11:34 PM
Numba1Sean
May 6, 2009 11:48 PM
redfan13
Mar 11, 2008 09:37 PM
Chadoo951
May 6, 2007 07:01 PM
