Replacement Headunit...
Old May 16, 2009 | 09:40 PM
Crestwood1001's Avatar
Crestwood1001 is on a distinguished road
Default Replacement Headunit...
I have a 95 blazer, what size headunit do i need? Its all one big block lol im not really sure what to do with it
Old May 16, 2009 | 09:50 PM
nj4x4blaze's Avatar
You can pick up a din & a half aftermarket radio from Pioneer. Or any single din radio with a install kit to fill the gap.
Old May 17, 2009 | 08:01 AM
Biohazed's Avatar
actually you can fit up a double din radio in a '95, you may have to make some bracketing up for the radio, but you can definatly do it fairly easily.
Me personally I have a single din Kenwood with a 1/2 Din Clarion EQ and with the picture, you can see there is plenty of room to put in a 2 din Radio.
Old May 17, 2009 | 09:15 AM
Thanks for the help guys, my rear speakers are not working and i took apart the right rear door and took it out, they are not getting power. But when i put the door back together the lock didnt line up right and now I cant open the door lol, how can i get it open to fix it?
Old May 17, 2009 | 05:43 PM
Biohazed's Avatar
ok is the lock jammed? did the power locks work before you jammed the lock? is it just stuck locked, or is the handle not working? try taking out the small panel behing the handle that houses the lock and see if you can get it freed up
Old May 17, 2009 | 06:24 PM
Power locks worked, I think when i put the door panel on i just lined up the slider wrong or something, which panel are ya talkin about?
Old May 17, 2009 | 07:01 PM
oisinirish's Avatar
Interior trim panel. Same one you had off to get to the speaker/wire. Then you may can reach the rods that go to the lock. Not sure on yours but there may also be a smaller panel around the door handle that you can remove providing the access you need as well.
Old May 17, 2009 | 09:28 PM
Na the panel around the handle does not come off, i had to work around that
Old Jun 6, 2009 | 10:18 PM
I fixed it ALONG time ago lol just pealed back that panel and lined it up right
TheDesertFox
Sep 2, 2006 03:08 PM
TheDesertFox
Jun 8, 2006 11:42 AM
Pugsley
Apr 21, 2006 09:02 PM
kornphlake
Apr 17, 2006 11:50 PM
jagblazer01
Apr 3, 2006 10:27 AM
