Running wires in 03 2-door
Old Feb 17, 2009 | 09:32 PM
  #21
cr8390's Avatar
cr8390 is an unknown quantity at this point
Default RE: Running wires in 03 2-door
dosent matter what you have my dads silverado stock bose speakers with bass up shakes his mirrors, the same thing goes for my moms caddy. Caps are bad if you use it your stupid, i learned the hard way
About the fuse holder i have mine next to my battery in the engine compartment.
Old Feb 22, 2009 | 06:21 PM
  #22
GABlazer92's Avatar
GABlazer92 is an unknown quantity at this point
I wired it on Tuesday the 16th and it turned out great. I had to mount the amp on the backof the sub boxbecause the power wire didn't end up being long enough. We mounted the fuse on the inside of the fender under the lip right behind the battery and before the ECM, we couldn't put the cover on the fuse, but it's fine. We had to run the power wire on the drivers side right beside the accelerator and the remote wire off the radio fuse. We ran those wires under the kick plate, under the sill plate, and then behind the panel in the rear to the amp. We ran the RCA cables the same way except on the passengers side.Aremote bass level controlcame with amp(look at the link for the amp and its the 3rd pic) and we mounted that under the wheel and to the right and ran the wire with the remote and power wires.We ran the ground wire to the rear seat mounts, which is a really good ground.I think the amp being "hidden" doesn't look bad at all. I'll post pics tomorrow when there's gonna be some light.
maxvamp
Oct 31, 2020 08:19 AM
Mrthelaxer
Mar 20, 2013 08:00 PM
rogggg1020
Sep 24, 2008 06:53 AM
Big Frost
May 13, 2008 03:36 AM
wankel7
Jan 21, 2008 06:30 AM
