Sirius radio install
Old Sep 12, 2008 | 11:48 PM
bigguy8786's Avatar
bigguy8786 is an unknown quantity at this point
Default Sirius radio install
Hey I have had my sirius radio for months now and all of a sudden my power cord broke so I decided to buy the professional install kit. I am pretty good with car stereos as I have installed many in my cars and my friends cars. My only question is that with the new installation kit I have to hook a power wire up to the accessory wire in the car. I am not exactly sure which wire is the accessory wire. Is it the yellow one? Also does anybody have any suggestions as to where to mount my sportster 4???
Old Sep 13, 2008 | 06:28 AM
xmradioguy's Avatar
xmradioguy is an unknown quantity at this point
Default RE: Sirius radio install
Yes yellow is the switched power
Old Sep 17, 2008 | 05:54 PM
bigguy8786's Avatar
Ok so I went to install my car kit today but for some reason i could get no power going to my sirius radio. I have an aftermarket pionner radio which was on display at circuit city so the guys at circuit city had already done a bunch of wiring. They had a tag on a red wire that said ACC which i figured was the accessory wire. I tried to hardwire into this one but got no power. I then spliced into a yellow wire which said +12v battery and still got no power. I then spliced into the original yellow wire that comes straight from the car and could not get any power. Any idea why I am not getting power??
Old Sep 17, 2008 | 08:33 PM
djdrew010's Avatar
djdrew010 is an unknown quantity at this point
did you ground it?
Old Sep 17, 2008 | 08:53 PM
bigguy8786's Avatar
i'm pretty sure that i have it grounded right....but would that make it so it would not power on at all? thanks for the help
Old Sep 17, 2008 | 09:24 PM
djdrew010's Avatar
If your radio is working fine you should be able to tap into the ACC wire(red wire), this is the one when you turn your key on the satrad and all accessories come on. then find a good ground, if you can't find one I would ground it with the black wire on the receiver.
Old Sep 17, 2008 | 11:20 PM
WolfPack's Avatar
is yellow really switched power back behind the dash? I've always stayed away from any yellow wire (airbag)! Then again...my IPFs are wired up with yellow wire...hah..
Old Sep 18, 2008 | 12:30 AM
djdrew010's Avatar
yea the thick yellow wire is the air bag but the thin yellow that has all of the radio wires with it is the constant 12v
Old Sep 18, 2008 | 05:25 AM
xmradioguy's Avatar
ORIGINAL: djdrew010
There is no red wire in a blazer for acc.
Constant 12V+
Orange
Switched 12V+
Yellow
Ground
Black
Illumination
Gray
Dimmer
Brown
Antenna
Right Front
Front Speakers
6 1/2"Doors
Left Front (+)
Tan
Left Front (-)
Gray
Right Front (+)
Light Green
Right Front (-)
Dark Green
Rear Speakers
6 1/2"Rear Doors
Left Rear (+)
Brown
Left Rear (-)
Yellow
Right Rear (+)
Dark Blue
Right Rear (-)
Light Blue
Old Sep 18, 2008 | 01:19 PM
djdrew010's Avatar
oops...then he should tap into the thin yellow wire my bad...
96Blazernut
Sep 28, 2009 07:17 PM
mcaanda
May 23, 2009 04:04 PM
kulls61
Mar 1, 2008 06:43 PM
KLBlazer07
Feb 27, 2007 01:23 AM
sledneck16
Aug 31, 2006 12:57 AM
